  New Posts New Posts RSS Feed - Unplugged wires?
Unplugged wires?
YooperSully View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote YooperSully Quote  Post ReplyReply Direct Link To This Post Topic: Unplugged wires?
    Posted: May-02-2010 at 11:55am
I have a tan hooked up to my temp sender. The wire in question is tan or faded orange with a red stripe. I've checked the wiring diagram and no wire like this exists on it.
87' 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2010 at 1:21pm
Roger,
Everything works? Chris is correct on the tan wire being the proper color for the temp sender.
BTW, the wiring diagram is is the reference section under manuals/PCM.
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2010 at 12:58pm
looks like the wire to the temp gauge sending unit that I don't see in the intake. Also has the alternator be swapped out to a single wire unit if so there would be two extra wires that wouldn't be used anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote YooperSully Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2010 at 10:55am
Yeah it runs, everything but the audible alarm works.
87' 2001
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: April-30-2010 at 3:29am
I will try to pull my cover and look tomorrow if no one beats me to it. Does it run? I thought most of those wires were pretty important. Engine looks pretty clean.
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote YooperSully Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2010 at 8:15pm
I'm looking on some info on what and where these three wires are/go? Two are off my alternator and one is from my wire loom. While spring cleaning I noticed them. They haven't been plugged in for over a year, as long as I've owned the boat.
Also in the quest to fix my oil on the inside of my doghouse I ordered a new tranny dip stick. My old one's rubber on the underside was cracked and rotted.
87' 2001
