Protech Distributor drop in? |
hotboat
Gold Member Joined: March-28-2009 Location: Conn Lake Pa Status: Offline Points: 814 |
Posted: June-20-2010 at 10:16pm |
try aligning the oil pump driveshaft with the bottom of distributor, I cant remember if its a flat head or hex. either move the distributor a tooth or two and work your way back if needed
Brian
tommer12
Senior Member Joined: February-05-2004 Location: United States Status: Offline Points: 366 |
I had to pull my protech distributor out when I did my heads... I cant figure out the correct way to put it back in. It wont drop the last 1/2" down. I assume this video explains a thousand words correct?
Any other tricks from the pros to get it to drop? http://www.youtube.com/watch?v=YdIGZ-tVuZA |
84 SN, 92 SNOB, 2005 SANTE 2006 SN 206
