  New Posts New Posts RSS Feed - Loud Exhaust on Take Off
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Topic: Loud Exhaust on Take Off
    Posted: June-23-2010 at 1:40pm
If the impeller isnt pumping water, you wont know it unless the temp gauge goes up- you certainly wont hear it.
I suspect youre hearing an echo effect on takeoff. The large wake thats produced at a slow (just on plane) speed, combined with a slightly more bow-up position causes some sound reflection. Ive noticed this on every inboard Ive ever driven.
davehurwitz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davehurwitz Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2010 at 1:13pm
It's definitely more than a different tone--sounds like the impleller isn't pumping water and exhaust is dry but as I said, no overheating and I changed the impeller.
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2010 at 11:40am
it's called harmonics nothing to worry about, the tone is lower at take off then increases in pitch as the engine's rpms come up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote davehurwitz Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2010 at 2:39am
Hi, my 2004 SN exhaust is loud on take off but it goes away after a few seconds. No overheating and I replaced impeller. No water in bilge from drain plug missing from muffler. Any ideas?
