  New Posts New Posts RSS Feed - oil on top of the intake manifold
gordonw View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote gordonw Quote  Post ReplyReply Direct Link To This Post Topic: oil on top of the intake manifold
    Posted: June-18-2005 at 1:53pm
You guys are right on. Thanks for all the help. Took it out the other day for a test run. I think it's the crank case ventilator. I torked it all down including the valve covers and havn't seen any oil. So I'm calling it good.
Kyle View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kyle Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2005 at 1:43am
Check the gasket of the raw water pump. at high rpm's or wot the h20 pressure is high and the pump can have a tendancy to spray through an old gasket. I have my lid cranked down as tight as I can and it still sprays. the liquid on the intake manifold could be a mix of oil/gas from the carbureator gaskets and water from the pump. open your engine cover and put the throttle at 4000. you might be surprised. my 83 commander does this as well.
Hope I could be of a help.
Kyle
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2005 at 12:35pm
My theory is that the crankcase ventilation hose is depositing oil on the spark arrestor and some of this oil eventually seeps down the arrestor and carb and settles on the intake manifold.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote gordonw Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2005 at 3:48am
Not really. I do have the iddle screw turned out all the way though. I have new spacer gaskets, fuel lines, clamps and so on. This motor has always done this and now I'm really stumped. I can clean it off and then the same amount of oil is back with in an hour. But after that it never really grows. Thanks.
jimbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimbo Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2005 at 2:36am
I noticed the same problem on my '84 Commander engine. My idle was running high so I replaced the carb/spacer and spacer/intake gaskets. The oily puddle went away. Not to mention the engine idled a lot better. Is your idle running high?
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2005 at 1:43am
Usually thats a gas leak on the carb, and over time the less volitile componets of the gas pool up and create a puddle of goo that resembles motor oil.
River Rat to Mole
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote gordonw Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2005 at 11:58pm
Yes mine has one but it's tied up around the impeller intake hose. The intake manifold gasket has been replaced and the problem existed before that also. Maybe it's somthing else simple? It must be the valve covers.
Wino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wino Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2005 at 9:32pm
Gordonw, do you have an oil drain kit on your commander? Is the hose pulled up and resting on your manifold? Mine is, and it leaks a tad bit, creating a small pool on the top of my manifold. Hope it's something this simple.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote gordonw Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2005 at 8:09pm
small amounts of oil are pooling on the top of my intake manifold. Mostly towards the rear of engine a 1980 351 commander. I"v changed the valve cover gaskets and the valve covers are stock and nearly straingt where the bolts secure. Am I missing somthing here boys? Thanks
