Throttle position off |
behindpropeller
Posted: September-14-2010 at 5:14pm |
The shift lever is splined and you can adjust it.
Didn't know if it was an index problem or shift cable problem. |
MartyMabe
Grand Poobah Joined: February-21-2006 Location: High Point,NC Status: Offline Points: 3980 |
Allen wrench to take off. When you have it off, check the backing plate(index plate) , it'll have 2 'notches' in it. See if they are 12:00 and 6:00 position.
bhectus
Platinum Member Joined: July-04-2010 Location: Gator Country! Status: Offline Points: 1809 |
thanks TRBenj, i will try that tonight.
behindpropeller, it has been this way since I bought the boat 3 months ago, it functions properly, locks into neutral upon return, just seems to be indexed at the wrong position. I am not sure if the cable has ever been replaced. |
'87 Barefoot - sold '97 Super Sport Nautique - originally custom built for Walt Meloon '97 Ski Nautique '83 SN 2001 |
Ive seen people do this so that the throttle isnt as far down (easier to reach comfortably) when at their common skiing speeds. To adjust, just loosen the set screw on the bottom of the lever, remove the lever and reindex. |
behindpropeller
Has it always been that way?
Did you replace the cable(s)? Does it lock so it will not go in gear by mistake? |
bhectus
hey guys, the throttle arm on my '96 SN is slightly off. It's neutral position is at approximately 1 o'clock. It doesn't seem to affect anything but it is annoying to me to know that it shouldn't be like this. Is there an easy way to adjust it back to the 12 o'clock position?
