  New Posts New Posts RSS Feed - Block drain/valve kit...
malcolm2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote malcolm2 Quote  Post ReplyReply Direct Link To This Post Topic: Block drain/valve kit...
    Posted: December-02-2010 at 2:02am
Did the part numbers you stated fit? I have a 92 351 Ford PCM direct drive and my block drain plugs are 1/4" MNPT. so i bought:
5 Each 4921K2, Drain-handle Brass Stop Cock Removable Handle, Internal Seal, 1/4" Npt Male.
Then for the manifolds: 2 Each 4429K423, Low-pressure Brass Threaded Pipe Fitting 3/4" Male X 1/4" Fem Pipe Sz, Hex Reducing Bushing.
I hate NPT I always get confused cause the 1/4" MNPT measures more like 3/8" diameter.
The PO had changed one drain to a bushing with the square plug, then rounded it off....one of the manifold plugs was rounded too. You could tell he used a 1/2" drive ratchet. The spring loaded ball on the drive did not allow for complete seating and then the ratchet slipped and buggered up the square hole. Someone had used vise-grips on the threads once too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: October-24-2010 at 1:17am
Originally posted by tommer12 tommer12 wrote:
Where do you get the handle/stem drain cocks for the PCM 351? I know mine are getting on their last legs and would like to get these valves to drain.
Mc Master Car Inc. has these drains. Look at the above thread link for all of the information. There is anothe thread going about pouring in antifreeze where all the information that you are asking is being given. Click of THIS THREAD that is above.
FYI,
Donald
tommer12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommer12 Quote  Post ReplyReply Direct Link To This Post Posted: October-23-2010 at 7:50pm
84 SN, 92 SNOB, 2005 SANTE 2006 SN 206
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2010 at 1:21pm
Originally posted by Waterdog Waterdog wrote:
Pete,
My piont is at sometime the block will have to be probed with a wire to remove some scale. It's not everytime the valve is opened or even once a year or 5 years. The openings on my ball valves are bigger than the openings on the petcocks.
I like the ones I have because they direct the flow of water into the bildge with a short peice of hose. When I've used petcocks I use a peice of sheet metal to direct the water so it doesn't get all over (the carpet, exhaust ect...)
They both work.
Andy,
I agree that both will work as well. Both can be probed with wire. I picked the removable stem petcocks way back since I didn't want true valves all over marking the engine look like some kind of a plumbers nightmare! Careful with the choice of ball valves. Most are not "full port" style which means the actual port is one pipe size below the thread size on the valve.
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2010 at 12:25pm
Pete,
They both work.
- waterdog -
78 Ski Tique
LKG_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LKG_ Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2010 at 1:23am
^ Thanks. I guess I failed in my search.
So it looks like 5X p/n 4921K3 removable handle stopcock + 2x p/n 4429k418 bushing/reducer.
Anyone know what size fitting is on my vDrive unit? It's a 1993 Nautique Excel.
Lake Gaston/Raleigh
North Carolina
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2010 at 4:35pm
Originally posted by LKG_ LKG_ wrote:
The manifolds are 3/4" NPT if I remember correctly. As far as I can tell, the only brass reducers they have that will mate up with their stopcocks are 3/4" to 1/4".
I sure can't remember all the stuff that Mcmaster has so I looked it up! Plenty of brass hex reducing bushings at McMaster!
Enter their part # 4429k418 It's a 3/4" by 3/8"
Double check the block drains. I don't feel they are 3/8". Keep in mind that pipe size goes roughly by the ID and not the OD.
From the other thread I linked:
Keep in mind that pipe sizes can be confusing. The OD of 1/8" is roughly .400", 1/4" roughly .540" and then at the manifolds, 1/2" .840" and if 3/4" 1.050"
3/8" will be .675"
LKG_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LKG_ Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2010 at 4:03pm
Andy (Waterdog)...I have seen yours; that's what made me decide to do something similar when I winterize this year.
I like the idea of the removable handle stopcocks. It looks like I can get three of them with 3/8" fittings for the block and thermostat housing for $6.42 each from McMaster Carr.
The manifolds are 3/4" NPT if I remember correctly. As far as I can tell, the only brass reducers they have that will mate up with their stopcocks are 3/4" to 1/4". There is no 3/4" to 3/8" brass reducer. So I could do a 1/4" stopcock, but that seems really small considering all the rust that comes out of those manifolds each year. What do you guys think?
Lake Gaston/Raleigh
North Carolina
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2010 at 4:00pm
Pete,
I'll open 1 drain at a time and if the flow is down then I'll take the pipe fitting out and probe the hole with .040 safety wire.
The samething you do with a pipe plug.
"If it's not stopped up with rust, it will be."
Andy,
If you need to remove the fitting or valve, what's the point of putting in quick drains?
I suggest using the removeable valve stem stopcocks that I've mentioned in other threads. The last time I mention them was in this thread
Here's the picture again. I've got them on all my boats.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2010 at 1:59pm
Pete,
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2010 at 1:32pm
What ever means of draining is used, being able to probe the drain hole with a piece of wire is of utmost importance.
You may also want to do some searching/reading here on site. There's quite allot of info on the subject - recent too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2010 at 10:39am
Andy,
   Didn't you see mine? Went into Agri-Supply and hunted for the fittings. all brass, reducers in the exhaust manifolds, 3/8 90* elbows, 90* 3/8 fittings in the block and a streight 3/8 in the U at the water pump All attached to 3/8 ball valves and rubber hose off the ball valve.
   I was thinking after draining I'd lift the hose up as high as possible and back fill with a turkey baster and anti-freeze then close the valve.
   Take your fittings to Gaston Hardware (46&48) Mike will match them up for ya.
- waterdog -
78 Ski Tique
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2010 at 10:30am
I put one together a few years ago at the local hardware store, it ended up saving me only the shipping cost from SKIDIM. Just take your plugs with you to the hardware store after you drain everything. It was handy, but I don't use that anymore, there are too many things to drain now that it won't get. (V Drive, transmission cooler, strainer, heater) There is enough room in the Excel to keep a small marine heater on a thermostat, and I drain it by hand if it looks like we are going to get into a long cold period, just for peace of mind.
LKG_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LKG_ Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2010 at 5:11am
Has anyone compiled a complete list of parts to make a quick drain kit for the PCM 351 yet? I want to add a kit like this when I winterize this year. The manifolds are 3/4" NPT if I remember correctly, but what about the block and thermostat elbow?
Is there one place to get it all (Tractor Supply Co., Northern Tool, etc) that anyone can recommend?
Lake Gaston/Raleigh
North Carolina
