Depth Finder |
kapla
Posted: October-26-2010 at 7:01pm |
check fluid level as suggested by Don. I have a uniden with the same type of puck..Had to reinstall puck after stringer rebuilt and over a month of use it lost all the oil due to a leak..and it read nothing..after resealing and adding oil again..it started to work again...
<a href="">1992 ski nautique
JLags
Groupie Joined: September-05-2010 Location: Florida Status: Offline Points: 58 |
Mine reads 00 most of the time and sometimes will show the depth but seems to be really far off.
TX Foilhead
If it s the same type as mine then it might be it just lost the fluid and needs to be re-sealed and refilled. I love mine, it's the only one I've ever seen that reads all the time and never does anything strange. I keep it set to read below the bottom of the rudder (the foils ride a little deeper), and I can see large rocks go by where we turn around.
JLags
Maybe I need to look at the transducer on mine, the one currently installed is a Faria
TX Foilhead
I dont have a good way to remove them, but I went with a Faria because it uses a cup that is siliconed to the hull. The transducer fits inside the cup and you fill it with antifreeze or mineral oil. I figured if it wears out or stops reading all I'll have to do is pull it up, clean it off and silicone it down again.
JLags
Can anyone reccomend a way to remove the old depth finder puck? It no longer reads depth and I want to replace it. The previous owner appears to have replaced it a few times with 3 old pucks stuck on. Also any reccomendations on which model/brand to replace it with? Thanks |
