  New Posts New Posts RSS Feed - SACHS DRIVPLATE#
SACHS DRIVPLATE#
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: SACHS DRIVPLATE#
    Posted: April-16-2011 at 6:30pm
Originally posted by Luchog Luchog wrote:
What would be the benefit of a cut down version?
isnt it better if the plate is held farther outside the flywheel?
It's a "fits all" engines (with a Velvet) plate so it's diameter is large enough to accommodate all 7 hole patterns of any flywheel. The Fords flywheel are smaller and that's why the trimming is needed. It may interfere with the starter nose.
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2011 at 5:45pm
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2011 at 10:53am
Sachs is a very reputable company, owned i believe by Borg and Beck, they are a very durable plate....and are made in a civilized country
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2011 at 4:26pm
3 bolts is all it takes.
Good... 'cause thats all we're putting on!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2011 at 4:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2011 at 4:10pm
The trimmed down version has less holes but you only use 3 bolts.
You only use 3 bolts regardless of whether its the cut down version or not, right Pete? I recall you saying that is just fine... only 3 bolts line up on our BFN/72C, whereas the original (round) damper took 6.
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2011 at 4:09pm
I didnt see anyone follow up, so I wanted to chime in and confirm what we all suspected (or knew but didnt explicitly say). The ALTA-106 damper available at ebasic power is in fact made by Sachs, though it is not called out on their website. Or maybe it is made by Alta with Sachs parts? Whatever- its the high quality damper Eric is always mentioning. Quite the deal for $60.
Sachs Damper at EBasicpower
They also sell the cut down version mentioned above for a few bucks more.
I´m surprised on the origin of the plate..Brazil..is the center an automotive part or marine specific?
<a href="">1992 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2011 at 4:03pm
Originally posted by Robb Robb wrote:
I had the same issue on my '74 and ended up buying the trimmed down Sachs (ALTDA-106A) from Basic Power for $90, but I was pressed for time. Also, you'll find that only 3 of the 6 bolts used on the factory damper will match up on the flywheel with the Sachs.
With the 7 different hole patterns/centers, it's supposed to fit any flywheel with a B/W trans.
21 holes in the standard Sachs plate
Robb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robb Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2011 at 3:53pm
Is this your experience as well Eric?
bbishop1974 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bbishop1974 Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2011 at 1:05pm
i changed mine because i was rebuilding the trans.upon inspection i found it to be completely rotted around the springs and they were all exposed.the factory plate has them enclosed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2011 at 9:55am
for reading purposes, when changing the damper, when at all possible, leave it finger tight and install the transmission to the engine and then come back in and tighten the bolts...this method will center the damper on the flywheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2011 at 1:34pm
Originally posted by malibud malibud wrote:
not to hijack but I assume this will fit my 85' 2001, 351 velvet drive ?
With the 7 different hole patterns/centers, it's supposed to fit any flywheel with a B/W trans. (the number of spines matches the Velvet)
Is your engine or transmission already out of the boat? If so, swap the damper- its good preventative maintenance. Thats what we're doing on our BFN.
If the powertrain is in the boat and you have no real need to pull it, Id be inclined to leave it be until it starts to act up. Having the plate on hand in case your original lets go isnt the worst idea in the world though- that way you can be back on the water quickly should it fail.
malibud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote malibud Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2011 at 1:26pm
not to hijack but I assume this will fit my 85' 2001, 351 velvet drive ? and my transmission works fine but I think it is all original should I replace the damper for preventive maintenance ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2011 at 9:02am
e-basic must have some buying power, walmart of damper plates, hate volume buyers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2011 at 8:59am
i have some coming in today
Post Options Post Options   Thanks (0) Thanks(0)   Quote bbishop1974 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2011 at 1:52am
thanks for the reply tim.i tried to purchase from ebasic and they were A-HOLES.dealt with 2 different people,would not take my order over phone and told me my computer was broken???long story but bottom line was i knew what i wanted and they made it rediculous.i gave up and bought the overpriced skidim unit out of frustration.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2011 at 11:07pm
Gary,
With the 7 different hole patterns/centers, it's supposed to fit any flywheel with a B/W trans. (the number of spines matches the Velvet}
The last one I put on the Tique and I did have to cut it down. I scribed the diameter, cut it on the band saw and then finished it off on the disk sander. The one I replaced on the Y block (same Sachs) did not need trimming.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2011 at 10:57pm
So I assume this fits all Ford flywheels? If it does not you have to cut it down to the smaller size or shell out 30 bucks more and get the "a" ? I ask because I have never changed mine and I'm thinking for 60 dollars it might be a good idea
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2011 at 9:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bbishop1974 Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2011 at 1:38pm
thanks eric,i was guessing it was because it was the 14 inch.12 inch would be for older models
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: February-02-2011 at 9:47am
106a, has the edges cut....about 99% that is the one you need
Post Options Post Options   Thanks (0) Thanks(0)   Quote bbishop1974 Quote  Post ReplyReply Direct Link To This Post Posted: February-01-2011 at 12:24pm
as always thank you for the quick reply .are these plates made by sachs?i see no mention of manufacturer.it looks like i will be digging out about 4 ft of snow to see what size flywheel i have.thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: February-01-2011 at 9:53am
da-106 or 106a...go to e basic power for now.
confusion always sets in..13 inch props wont break a sachs
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-01-2011 at 8:58am
Brian,
Mer changed their web site all around and it seems the nice pictures/descriptions of the Sach's plates are gone. I've used several of the Sach's plates but of course didn't save the part numbers!!!
The key is the number of splines that matches the Velvet. Then, the plates were "universal" with about 7 different hole patterns to bolt up to whatever flywheel.
I've never heard of a strength issue with them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bbishop1974 Quote  Post ReplyReply Direct Link To This Post Posted: January-31-2011 at 5:58pm
could anyone help me verify sachs driveplate plate# for 86 SN 351,B/W VELVET DRIVE.i have seen it posted in past and wrote it down,part#80106,availible through MER equipment.i called to order it and they question wether it will be strong enough.i know Eric uses them.thanks for the help
