  New Posts New Posts RSS Feed - Fuel Tank
Fuel Tank
Jllogan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Tank
    Posted: June-21-2011 at 3:41pm
Or you could just toss a match in and take it to be welded when the fire goes out
TheChad1976 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TheChad1976 Quote  Post ReplyReply Direct Link To This Post Posted: June-21-2011 at 3:34pm
I will see if I can get a picture of it. Yes the weld that was on there to hold the threads for the pickup tube broke completely all the way around. When I pulled the pickup out it was still screwed into the weld. I guess it could be welded but it still has 1/2 tank of gas to be siphoned and dried REALLY good..
TimSpangler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimSpangler Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2011 at 10:36am
Look in the for sale section, I have one if you are interested in it. Shoot me an email.
tim <dot> spangler <at> gmail <dot> com
It is out of an '83
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2011 at 8:23pm
Originally posted by lakedog55 lakedog55 wrote:
Or you could take it to a welding shop and the could fix it
Absolutely a great idea! better than the "JB"weld !!!!    Any one with a TIG AC welder can help out. I'm confused about what broke off? The threaded flange on the tank? WOW, they are normally welded on there pretty good! How about a picture?
lakedog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lakedog55 Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2011 at 8:10pm
Lakedog55
Post Options Post Options   Thanks (0) Thanks(0)   Quote lakedog55 Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2011 at 8:08pm
Look in the parts for sale their was a guy from jax, that had a ton of parts.
Mike
Lakedog55
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2011 at 2:32pm
Not totally sure, but I'd have to say they've been replaced before. There's a thread called Separateror Rebuild and I know he had a tank made totally custom. I think that was more of a one off situation though, since it was in infloor tank.
I'm sure if you find a thread where someone has done a full resto on a "2001" hull, and there are a few, you may see what they've done with their tanks. I think a lot of them came with plastic tanks anyway, but not sure of the drawbacks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TheChad1976 Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2011 at 12:25pm
Has anyone replaced there fuel tank and if so where did you get it? I have an 87 2001 Ski Nautique and someone had "JB Welded" the pickup in it so need less to say when I went to pull it out to clean it ripped out of the tank. Should I stay with an alluminum tank or would a plastic tank work just as well?? Open for suggestions.
