  New Posts New Posts RSS Feed - rudder bushing?
rudder bushing?
HOLESHOT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HOLESHOT Quote  Post ReplyReply Direct Link To This Post Topic: rudder bushing?
    Posted: August-23-2005 at 3:56pm
jameski thanks just whated to know whats up there before i take it off to do the drive shaft bushings
IF IT HAS A SPARKPLUG I CAN FIX IT
jameski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2005 at 10:46am
There is no bushing. The rudder shaft turns in the housing. If you are wanting to tighten up excessive play, the only thing you can tighten is the packing gland, and it really won't help much.
FWIW, my '78 has quite a bit of play (the bottom tip of the rudder will move back-and-forth about 3/8"), but it has NO negative effect on my steering. I used to have some problems with play in the steering, but most of it was at the clevis on the rudder arm. I took it off and bent it to remove the clearance and now my steering is perfect.
current boat
94 Sport Nautique
previous boat
78 Martinique
Post Options Post Options   Thanks (0) Thanks(0)   Quote HOLESHOT Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2005 at 2:59am
hey has anyone removed the rudder from there cc
and if so what is in there for a bushing or bearing . please help thanks
