78/79 ski-tique rod knocking |
Post Reply | Page 123 7> |
Author | |||
eric lavine
Posted: October-09-2011 at 11:49am |
and dont be a dummy and put teflon tape on the threads, flares do the sealing not the threads, I dont own any teflon tape that *************** gets everwhere so i use pipe dope, the only place you should see dope or teflon tape is on a NPT National pipe thread.
just brought that up cause i always see teflon tape hanging off the carb fitting |
Dreaming
I didn't know those were available I learn something new on here all the time! |
JoeinNY
Speaking as a guy who sets his boat on fire every now and then... regardless of regulation you do need to be a little careful in your fuel line selection on a boat. The specifically what is needed between an engine mounted fuel pump is something abrasion resistant (to avoid wearing through either by vibration over time or by contact with a rotating pulley or belt) has positive stop stress relieved attachments (ie not a non flared compression fitting on a hard line that could be slowly and imperceptably pulling out, or a soft line with a clamp and a barb fitting because it also could blow out under pressure suddenly and it could through fatique crack over time) and something that has a high enough melting temp to allow you enough time to swim away should you have a small thermal event under the motor box.
A high quality rubber hose with stainless steel braiding and AN fittings properly used meets all these actual requirements. But there are no markings on stainless braided lines that seperate the cheap low melting point rubber junk from the high qualily stuff that will give you enough time to swim away. That is more an issue for the coast guard because they cannot easily check than it is for you who can check the specs of the material you buy. |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5781 |
You have to install a flair adapter to use AN fittings. as for the almighty "Coast Guard Approved". Screw them, You can plumb airplanes and tanks with these fittings but question putting them on a ski boat, give me a break please. They are absolutely leak proof and can be removed and reinstalled countless times without leaking, try doing that with a double flair piece of crap. I go for peace of mind with my boat and I never started my motor without checking that dam fuel line flair, never a drop of fuel out of the AN's. Common sense is a terrible thing to waste. |
BuffaloBFN
Didn't we recently see AN fittings on a metallic blue Ford?
Kinda of ironic,AN fittings,Army Navy are not good enough for the Coasties???
Dreaming
CG rating is important, but another concern is that the flares may be different. I can't remember which is which, but automotive and aircraft use different flares, one is 45 Degrees, and the other is 37.5 degrees. using the wrong flare will make the fitting leak |
Luchog
after your done with the fuel line, pull the plugs and crank, if it's turning easier timing is too advanced, put the plugs back and retard timing. If it doesnt, the starter is tired and needs rebuild.
always guessing the engine is properly assembled. |
To my knowledge, they are not USCG rated. |
allanonjj
Groupie Joined: August-17-2011 Location: THOMASVILLE, GA Status: Offline Points: 94 |
OK,.. I'll order the one from skidim. Ive heard that its not a good idea to use steel braded line with an fittings,.. why is that? |
JJ,
I bought one from Skidim for my 302. Since it's gots a wedge plate under the carb, some tweaking was neded but it worked. The alternate is to use pre flared brake line and bend one yourself. |
Dreaming
I bought a lenght of fuel line at the auto parts store (steel of course) and bent with a tubing bender... tube was all of about 6 bucks. if you have to cut some of the tube off to get the right lenght, the end is a double flare... single flare will not seal as well.
Bri892001
You got it, that's the right fuel line... or should be if you have a stockish intake manifold. On Holleys, the gas line goes in the front towards the port side.
allanonjj
http://www.skidim.com/prodinfo.asp?number=RA085002B
Is this it? It doesnt look right but it may be the one. I thought the fuel inlet was on the right rear side of the carburetor,.. right? Does anyone have a good pic of this? |
allanonjj
Hey Pete,.. where'd you say I can get one of those? There was some site or something that sells them for like $20 or so but I forgot where it was. |
You can also put your finger over the holes. One will suck and the other develope pressure. Don't forget the steel line with flared fittings from the pump to the carb. |
allanonjj
K,.. preesh |
look at it close usually one if not both are marked inlet or outlet
allanonjj
another silly question: On the fuel pump,.. which hole(front/rear) is the inlet and which is the outlet? (I took pictures of all the stuff I knew I'd need visual reference on and forgot to on the simple things,... lol)
storm34
I'd say timing. When I attempted to start mine for the first time it would spin and then stop dead in it's tracks and then start up again. I had plenty of fuel but the timing was so far off it wouldn't ignite.
If I remember right, I set mine at 10 degrees. It's silky smooth there and starts ridiculously fast. |
allanonjj
I first tried "cranking " the engine without the spark plugs hooked up,.. just to see how it sounded without fire. |
allanonjj
Im not sure of the starter age,.. it seemed strong on the old longblock but I dont know how much abuse its been through. Its funny though because IT looked younger than all the other parts on the motor. As for the timing,... the engine wasnt even close to starting,.. it wasnt turning over fast enough to crank so that isnt my biggest problem yet. That brings me to a good question. Where would you set the timing on a fresh build? |
Not having the dust shield in place will not affect the starter's functionality.
You do need a marine starter. It also needs to be reverse rotation specific- the starter will be CCW. If youre using an automotive starter, not only will you have in adequate spark protection on it (big safety no-no) but it will also be trying to turn the engine backwards. |
allanonjj
Thats what I was thinking,... Ive built SEVERAL hi performance 4cylinders and they felt buttery smoothe. There is one thing that I didnt tell you guys yet,.. I felt really stupid for missing it but I dont see how it would make that big of a deal when trying to crank it...... When I mated the tranny I forgot to put that "dust shield" cover or whatever it is called back in between the block and tranny. Its VERY thin but the starter did originally mount on the outside edge of it,.. so now the starter is a half a millimeter or so further "in" to the tranny. That means that the starter teeth arent in the EXACT same spot they were. Like I said, I dont really see how this could affect anything but is is slightly different than before.
If I have to get a starter does it need to be a MARINE starter or will automotive parts be ok? |
JoeinNY
Sounds like bull to me.. a properly clearanced and lubricated engine has no reason to be more "tight" than any other. It could crank hard due to starter issues, and it could have the timing way off causing hard cranking due to sparking while the piston is on the up stroke.. but other than that if anything the rings not being broke in should increase blowby and make it easier to turn over. With the plugs out you should be able to turn the engine over with a half inch rachet on the crank.. it shouldnt feel tight.
Luchog
what's the starter condition? a tired starter and a freshly built engine isnt a good recipee. Battery condition?
Also timing might be too advanced. |
allanonjj
Have any of you tried to crank a fresh 302? Mine seems really "tight". It's not spinning over very fast and it is putting a strain on the starter. I talked to Mack about it and he said that it is normal, that a freshly built v8 can be a bitch to start. Just wondering if any of you have experienced the same issue.
SNobsessed
Yes that is the correct map
allanonjj
Im still alive,.. just had to put the engine project on hold for a little while. I did get it back in the boat yesterday and got most everything hooked up. I have a stupid simple question: If the firing oorder is backwards does that make the cylinder #s change? Could someone show me which cylinder is which please?
Is this right?: rear seat 4 8 3 7 2 6 1 5 windshield |
JoeinNY
I might not be picking up what you are putting down, but the rear main is surrounded on the bottom by the rear most main bearing cap,
although I can see how it might not look like that .. |
