transmission oil |
Posted: August-19-2011 at 6:41pm |
Whats in the transmission now? (20w oil is brown, ATF is red.) 20w is fine to run... if you can find it. Swapping over to ATF is not a bad idea either. The fluids are compatible, but plan on 2-3 changes to get most of the oil out. If you go that route, stick with conventional (NOT SYNTHETIC) ATF, either Dex/Merc or Dexron III. Avoid high mileage formulations as well... additives are bad.
I can usually get about 1.5-2 qts out per change. Capacity is a bit more than that. I use a vacuum pump, but drill pumps work fine too. Use the dipstick hole, not the drain plug. Be careful that you put the extraction hose in the hole straight! |
Tadpole
Groupie Joined: September-26-2008 Location: Massachusetts Status: Offline Points: 51 |
How many quarts of oil should I put in it and what is the easiest way to take the old oil out.
1993 Ski Nautique
Tadpole
My pcm40a transmission says to use 20/20 w motor oil. Can somebody help me out here?
1993 Ski Nautique
