68/69 Mustang Resto |
Post Reply | Page 123> |
mountaineerminer
Groupie Joined: May-03-2011 Location: Bristol, TN Status: Offline Points: 79 |
Posted: January-05-2014 at 1:58pm |
Thanks Gary,
I ended up making the hole much bigger than that, haha! Since I don't have a center console box I left the pylon support intact. I am planning on building a mold and making a box to fit into the console once the boat is put back together. |
Mike,sorry I dropped the ball on your posts,I missed your question completely. This is the best picture I have of where the console went,
CC just cut everything away where the console went. They cut the cross member out in the front where the controls are,you can see where I replaced it and they cut into the pylon mount for clearance for the glove box. I ended up cutting a section out of the box and making it shorter rather than cutting into the pylon mount again This is the best picture I have for the control cut out, this is my sub floor. I also had to cut thru about half way thru that cross member in the first picture too. |
mountaineerminer
mountaineerminer
John,
I just saw your post on the pitot. I had stopped posting but have not stopped working on the boat, haha. I have been exceptionally busy with work the last several months. I actually just found NOS pitots for sale on ebay last week. I bought 2 encase I ran one into a log or something. They have more available, here is the link; http://www.ebay.com/itm/231058716243?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 I need to get some updated pictures up soon. I have gotten a lot done so far. Mike |
john b
Grand Poobah Joined: July-06-2011 Location: lake Sweeny Status: Offline Points: 3241 |
This may be a little late, Mike, but here is what the pitot looks like. I finally remembered to bring it home and take a photo.
1970 Mustang "Theseus' paradox"
If everyone else is doing it, you're too late! |
mountaineerminer
After a test fit of the console and controls I would say your right John. You need all the room you can get for a smooth radius on the cable.
That leads me to another observation. Although my boat has an MSS serial number, it probably did not have the console from the factory…. At a crossroad once again! |
john b
Yes, I believe the floor is cut out all the way to the hull, but don't take my word for it. I am far from an expert. Wait for Gary or Vondy or another export to reply before you do anything.
mountaineerminer
Gary, John, or anyone else intimate with the center console SS boats of the mid-late 60's; is the deck/sole depressed under the console? I know the floor pan has a cut-out where the console mounted, but what about the glass and foam under the pan?
I am mocking up the “plumbing” and started to think about routing the control cables. The set of controls I have extends slightly below the bottom of the console and will need a depression to extend into. Thanks for any insight, -Mike |
mountaineerminer
Looking for a tip or some insight:
When replacing the blocks that the exhaust tips go through what is the best way to duplicate the compound angle of the hole in the wood? I used the old blocks as a guide and drilled them out with a hole saw before glassing to the transom. Although this seemed to accurately duplicate the angle of the hole it is a little difficult to line up accurately. More than likely I am just being too nit-picky and the tips where not perfectly straight to begin with but maybe I am missing something. Thanks! |
john b
Just another thought. Cutting the sleve shorter will necessarily result in higher loading on the remaining surface area and less vertical stability. It may be that surface loading is not particularly important and the compromise of a shorter sleve provides some desired handling effect for some reason, but the fact that it cracked would cause me to carefully consider whether I want to subject it to even higher loading pressures.
john b
Do you mean me? I am always around, call anytime even if just to talk. Be aware that I really have no knowledge pertaining to the rudder assembly that will help you make a decision. There are others here who have experience and, most likely, have good answers. My Mustang project is easy, I am, to borrow a phrase from Pete, just keeping it original. I don't intend to change anything except the automotive carburetor. It is interesting that my 69 & 70 Mustangs have different rudders. I think the ports are the same, but I would have to check to be absolutely certain. Yours is probably the same as the 69. My spare rudder port is up in the "Land of Cheese". |
peter1234
Grand Poobah Joined: February-03-2008 Location: United States Status: Offline Points: 2756 |
Gary yes I only changed mine because it was bent and Reid recommended shortening it (it seems to have helped). even if he cant reuse the cutoff portion on top you can get bronze or brass spacers i believe.
mountaineerminer
Gary,
I guess under that theory I could even cut off the cracked portion (keep from spreading)and use the spacer between the rudder and the bottom of the rudder port to maintain the same length if needed. Or, I could braze or silver solder the crack.... I am worring about this now because I am getting ready to fit the wood at the stern that the rudder port goes through and I dont want to set it up for my current rudder port if I need to replace it with a slightly different version. John, Will you be around tomorrow? I wanted to give you a call, I had a few questions. Thanks guys! |
Peter wasn't it you that had a thread going about the poor hi speed handling of your boat? And wasn't it Reid ? that suggested shorting the rudder port.Looks to me he could cut it off where the crack stops and it will still be longer than the hull thickness.He would have to shim the top to make up the difference.
SNobsessed
For reference, www.deepblueyachtsupply.com sells these type of items.
Used is the way to go, they are expensive new! |
peter1234
i replaced mine this yr with the closest thing i could find it was from buck algonquin and all dimensions were right except the lower length , i just shortened it to match my old one . the other difference is that the port is much thicker but the hole in my hull had room for it .
john b
I have a spare rudder port. If you need one, which it looks like you do, ill put it on ice for you when you're ready. I will keep it as spare parts if you go another way. In any case it will be here.
I am feeling better about parting the 69 Mustang knowing that much of it will help keep others on the water. |
mountaineerminer
Hardware Questions,
Am I correct to assume that I should replace my rudder port due to the crack seen in the pic below? If I do need to replace it, where is the best place to find the correct replacement? The ones listed on N3 and NatiqueParts seem to be outside mount and Buck Alogonquin dosent appear to have anyting in the correct diminsons in an inside mount(4x4 flange, 3" bolt spacing, 2 1/2" under flange). Getting the cart before the horse on this one, but.....does anyone know of a replacment for the thru-hull speedo pickup/pitot tube? Has anyone had luck fixing a damaged one? Thanks! Mike |
john b
Bet it wouldn't spank the 134cid minivan in our chapter, or my old turbo minivan (mini) either. It may be a match for my 89 turbo GTC.
mountaineerminer
ya....i had a thing for late 80's turbo cars. I have had 2 Supras and a 300zx. its funny because 300HP was amazing them...my trailblazer SS has 400hp and would spank both with a boat behind it, lol
john b
Turbo car? I love turbo cars! 13:39 @ 109. Not nearly the fastest 2.2 in my chapter of the club, but a good sleeper! turbo cars |
I filled the console gauge holes in Mike because in John's and mine they installed them in the dash that year. I can't remember your year but by the look of the dash some gauges must have been in the console.
Mine- Johns- Diary posting- |
A BIG thank you.I didn't realize they had a ridge,don't think I'll be able to find them but diameter will be easier now. Just like everything else CC they must have had different consoles over the years,heres mine out of a 'Cuda,it's just taller.John brought your white one over on his visit. If I cut the lower portion off,it's identical.
mountaineerminer
Kinda of a second post on the same question...I am far from convinced that is the correct mirror for a 68-69 Mustang, it should be much smaller i think, but was it originally attached to the windsheild or the dash?
Minus the hour meter I think the gauges are in the correct position. What are eveyones thoughts considering I will be reinsalling the center console. Fuel, oil pressure, horn, bilg, and blower are to the right of the steering wheel. Mike |
mountaineerminer
Thanks John...I might need to make my way to the windy city again. Last time I was there was 7 years ago when my father and I went to pick up parts for an 88 Toyota supra turbo. It was a good trip, only our Yankee asses didn't realize we changed time zones!!!
john b
I'm glad you're happy with it. It deserved a good home and I know it found one. I hope to see your Mustang when its done.
mountaineerminer
Long time no post,
Since my last post I have completely ground out the hull and most of the sides using both a 4 1/2" angle grinder and a 7" angle grinder both affixed with a flap wheel. All the old gel in the bilge was removed as well at the unwetted glass under the old stringers. I roughed up the entire hull, but will do a final sand with a DA prior to glassing. This process seemed like an eternity and took place over about three weekends. Before rolling the hull in the garage I laminated the stringers using US Composites epoxy and two layers of glass cloth, cut, and sanded to final dimensions. Below are some pictures of the glove box, console, and controls that I picked up from John B and Aaron. The brown console on the right is supposedly from a Barracuda SS. Its definitely different than the Mustang console as it was made to run into the motor box with the battery directly behind the console. I purchased this console for the controls. John, The holes in the corners of the glovebox fit up exactly; I take this to mean that this boat was originally equipped with the glove box and it wasn't an after thought some time in the last 40 years. I will just have to fill the holes that the aftermarket box was installed with. Gary, I have finally taken some measurements of the knobs for you. Diameter of the ridge around the knob Measurement from the flat threaded end to the round top The next 2 images show the closest measurment I could get of the full diameter of the knob minus the rigde and flat spot. Mike |
BuffaloBFN
Initially I was very concerned about this. It turned out to be a non-issue with my '88. +1 on what Roger said about replacing stringers one at a time...at least on the mains. |
uk1979
Platinum Member Joined: June-13-2007 Location: United Kingdom Status: Offline Points: 1423 |
Mike The way I see it supports each side of the transom and 2 each side of the chine in line with the windshield should be fine some add a support to the keel as well just before the pylon its up to you, making up ribs would work too but allot more work and ensuring the hull is true and level could be a pain to do. There is the argument that depending how big a guy you are you will push the hull out with your weight which is a fair point but my guess is the hull would run faster. My self I took the sub stringers out first and replaced then took the main stringers out one at a time and replaced using the old to hold the hull shape while the hull was up on 4 stands this way will take allot longer to do but you can use the old to register/brace the new,if your going for a all out approach I do feel leaving 2 or 3 small tabs of the old glass sticking up 1/4 or so on the stringer runs make life easier registering the new. With your set up of lifting if you clamp some timber across the deck and plum down at marked points to the hull then lift and plum down again we can see how much flex there is once all the stringers are removed as I have not see this data on here and would be a great help for the flat bottom boats. |
Lets have a go
56 Starflite 77 SN 78 SN 80 BFN |
mountaineerminer
"The answer to the argument will be to meet back here in 25 years time and see how all the different materials used in replacement stringer jobs have faired!"
Must_Dash, My thoughts exactly... "when it’s time to refit the stringers may be good to support the hull off the cradle at the transom and each side at the chine" uk, This is a concern I had and plan to look into a better way to support the hull. Do you think I am better off trying to support it from the chines and transom area or building 4 or 5 bunks that run parallel to the transom? I am not sure how to describe this all that well; I might just need to describe in a picture. Gary, I will try and get some pictures of the knobs with dimensions tonight. I definitely think I will be trying to cast some new ones; the old plastic/resin feels quite fragile. -Mike |
