  New Posts New Posts RSS Feed - Materials needed
Materials needed
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Topic: Materials needed
    Posted: October-17-2011 at 12:53pm
Originally the boat was made with polyester resin. Epoxy resin is absolutely that much better for many reason. Number one being that it is not hygroscopic.
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2011 at 12:48pm
epoxy resin is (a) fiberglass resin.
Roym View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roym Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2011 at 12:02pm
Does everyone use epoxy resin instead of fiberglass resin?? Can regular fiberglass resin be used, or is the epoxy resin that much better.
vondy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2011 at 1:14pm
Yeah I messed something up with my flikr account and they vanished. I'm going to try to go back and edit them.
I believe I just did one layer of cloth top and bottom for the plywood floor. I don't see any reason to do more than one on the bottom. You could double up the top if you want. I have a vinyl floor glued to the top so I figured that would add to the waterproofing. Didn't do the sides of the plywood, I tried to wrap the cloth around but that failed miserably. I also did not see much of a point since the sides will be bedded into thickened epoxy against the hull anyway then laid over with cloth. Just CPES'd it all real well.
Now that I think of it, I should have gotten more cloth. I just ran short on the floor and had to use some biax for some of the smaller pieces under the bow.
For the biax, I don't think there was a smaller roll. Some guys double up there biax so if you go that way you would have plenty. I think one layer was more than enough for mine.
I'll see what I can do about the photos.
Roym View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roym Quote  Post ReplyReply Direct Link To This Post Posted: October-16-2011 at 12:14pm
Vondy
I looked at the Mustang thread, but most of you photos are gone. I would of liked seeing them. Sounds like you did a great job on your Mustang.
You think your revised material list was close, except there was too much biax ?
I'm thinking on the plywood floor just one layer of cloth on both sides and ends. This should be enough to seal the wood up good I would think. Is there any reason to use more or a different material??
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2011 at 11:37pm
the only parts I glassed before bedding what the underside of the drain channels.
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2011 at 12:05pm
Originally posted by Roym Roym wrote:
I do have a question. Once you get your stringers cut to fit, do you just soak them up with the CPES,let em dry and then bed them in
This option.
1988 BFN-sold
Roym View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roym Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2011 at 11:50am
Thanks for all the responses. I have been reading the posts, and now getting a feel for what to do.
I do have a question. Once you get your stringers cut to fit, do you just soak them up with the CPES,let em dry and then bed them in, or do you cover them with FG cloth and epoxy, before bedding them down.
It may be a few weeks before I start on this. I am rebuilding the bunks on the trailer now and repainting it. As I have the correct trailer for the boat, I want to keep it in good shape.
KFD14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KFD14 Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2011 at 12:34am
Clear Penetrating Epoxy Sealant. Magical stuff. You'll want to put several coats on every piece of wood before it goes back in the boat. It will help prevent rot in the future and seems to help the fiberglass bond to the wood better. IMHO
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: October-15-2011 at 12:32am
Penetrating epoxy, you paint it on all the wood to seal it up before you put it in the boat.   That way even if the water gets past the fiberglass the wood is sealed. You don't want to have to redo it that will probably insure that it out lives you.
Roym View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roym Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2011 at 11:57pm
I know everyone knows this but me. What is CPES?????
Post Options Post Options   Thanks (0) Thanks(0)   Quote vondy Quote  Post ReplyReply Direct Link To This Post Posted: October-14-2011 at 5:22pm
Roy,
Take a look at my stringer thread.
mustang
Down on page 3, I have a few screen shots of my order from US composites. It was just enough material for my Mustang. Literally had a few inches left of some of the fiberglass tape. I went no foam and added some ribs. I did have half a role of biax and just about a full box of cabosil left over.
Got my CPES from the Rot Doctor.
Harbor Freight for chip brushes and gloves. You'll need several boxes of both. I probably went through 6 boxes of gloves. And you'll need a ton of acetone, you'll be bathing in it pretty much, that epoxy gets everywhere.
I tinted my epoxy for the bilge color. It worked great. The tint is very cheap, just thicken it with cabosil until it resembles latex paint and brush on several coats.
Words of advice... give yourself plenty of time and don't rush, it will kill you. And the worst part is putting everything back together. Nothing ever fits just right. Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2011 at 6:47pm
Originally posted by Keeganino Keeganino wrote:
If you read through the threads you will see that a typical rebuild takes 10 gallons of epoxy.
On a typical 16' rebuild, Id say that was pretty close. I bet that he'd be more likely to put in a 2nd order for more than to have some extra left over though.
Roy, youre going to have to decide on a layup schedule on the stringers and floor before you can figure out a material list for the glass. I put a pretty good list together for our Barefoot Nautique, which I shared here. I also detailed my planned glass schedules on the mains, secondaries, ribs and floor. We stuck to it pretty close. You can probably detune the glass list by 25-50% based on your smaller boat and the fact that youre not putting in as many ribs or doing any laminating. I am afraid to check my resin supply, I fear we ended up using closer to 20 gallons.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2011 at 6:41pm
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2011 at 6:41pm
I got some tint for the epoxy that I never used on the bilge, but Ive used it one some other things and it seems to make a nice very durable finish coat. I ordered 5 gal of epoxy so I had quite a bit left over.
Roym View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roym Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2011 at 6:40pm
Have you actually given it much thought? Or are you just defaulting to what you assume to be the easiest solution? I can give you a few reasons why you may want to reconsider based on personal experience.
No I haven't, but your right,I need to think it through to the end. I am open for any suggestions.
To do the whole stringer replacement, all the secondary stringers, braces,and other wood items, and coat the bilge with epoxy, what would I need to order from US Comp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2011 at 3:51pm
TR, I understand what you are saying now. I'm thinking of just painting the bilge.
Its a ways down the list on priority at this point, but something to consider if youre trying to limit yourself to one fiberglass order!
Roym View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roym Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2011 at 1:58pm
Keegan Thanks for the link.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2011 at 1:35pm
What color bilge paint is a little premature at this point.
I didnt ask what color, I asked what material you planned to finish with. If epoxy or gelcoat, you'll want to account for that in your materials order.
Im with you on a foamless rebuild. I would recommend adding some ribs and bulkheads perpendicular to the main stringers that the factory did not use. This will lend a little more strength to the hull-floor structure, as well as give you good floor support (especially at the seams). They will add to the required materials (glass and resin) though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2011 at 1:03pm
Here's a good read for you my 73 Skier Restoration. This will answer most of the beginner questions since I knew very little at the beginning of this project. Everything from what materials, and layup schedules are detailed in this thread.
1973 Skier
Roym View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roym Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2011 at 12:58pm
Well my plan is to replace all the wood in the hull except maybe the rudder plate. If that is bad it will go too. I do plan on replacing the lift ring wood and the pieces where the exhaust exits the hull.
I haven't cut out the floor yet, but it's no secret the wood under it is mush.
My plan is "No foam" and a plywood floor. I might be way off base but I see the foam as being the cause of stringer rot in the first place. It appears to trap water,causing rot. I would prefer that it be open so the water can drain and be pumped out.
I really have no clue about how to do this. I assume from reading once the stringers are cut you wrap them with fiberglass cloth and "epoxy" them instead of using fiberglass resin. Then bed them in using epoxy mixed with a thicking product. As far as after this I guess it is epoxy and FG tape. I'm not sure how it goes after this, guess I'll keep reading.
I plan on using Douglas fir for the main stringers, as that seems to be the first choice. My son has called around, and said we can get it here in Florida, but might be a special order. I am open for other suggestions on this, if there is another choice. I have 35 Cypress trees in my back yard and a chainsaw . Just kidding!!
I guess I will use pine and plywood for the rest of the wood.
Thanks
Roy
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2011 at 11:27am
Agreed.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2011 at 11:17am
I figured that may be the case, but those questions should spur some thought, if nothing else. In general, it makes sense to complete the design before you order parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2011 at 11:10am
Tim, you might be one step ahead of him?
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2011 at 11:07am
That wouldnt be too hard for us to put together for you, but some more details on how you plan to rebuild would be helpful.
-What material are you using for the stringers? Wood? Composite?
-Are you refoaming? If not, are you adding any other structural members in addition to the original stringers?
-What material are you using for the floor?
-Have you decided on a material (epoxy vs. poly vs. vinyl)?
-Have you decided on a layup schedule on the mains, secondaries, ribs (if any), floor, bulkheads?
-Are you replacing the other wood in the hull? Lifting ring backers, rudder port, bilge pump mount, etc.
-Have you decided on a bilge finish yet? Paint vs. gel vs. tinted epoxy, etc.
Roym View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roym Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2011 at 10:29pm
After several years of "Thinking about it", I decided to start replacing the stringers and floor on my 77 Ski Tique.
I have searched and read many of the older posts but am unable to find a materials list for a Ski Tique. I know that several people have performed stringer replacement, and must have account of what was needed.
I would like to know how much epoxy, fiberglass cloth, filler etc. was needed. I don't want to order the wrong things, or the wrong amounts.
I'm a newbie at fiberglassing, so I need all the help I can muster.
Thanks
Roy
