  New Posts New Posts RSS Feed - How many more years
How many more years
dwcar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwcar Quote  Post ReplyReply Direct Link To This Post Topic: How many more years
    Posted: November-03-2011 at 1:59pm
Check all the lines above the RWP. Also check the thermostat housing.
83Ski
Roym View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roym Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2011 at 3:17am
Originally posted by dwcar dwcar wrote:
Be sure and find the missing pieces!
They are really missing pieces, as I can't find any of them. I guess they just were chewed up and passed through the system. If that's not the case they are probably hung up in the cooling system somewhere, but there's no way to know, or get them out. I will pull off the hoses and look for them there.
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2011 at 10:58pm
one misconception on these rubber type impellers is even if all the blades are intact you may still get an overheat situation, water doesnt compress so at times the blades will bend when they lose their elasticity and will by-pass water... Im like Pete, no problem, run it. but i just thought i would throw that bit of info out there
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2011 at 8:15pm
Maybe you can use it as a hockey puck for a few years . . .
skicat2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skicat2001 Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2011 at 3:02pm
I wouldnt take the chance on that impellar. A cheep part could put you in danager at any point in time next yr. I would change it, espcially if the some of the teeth are missing..
1985 CC 2001-SOLD
Lee Michael Johnson
Jllogan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2011 at 2:58pm
When I bought my boat from the PO there was no round pieces left on the end of the impeller basically the outside half each impeller blade was missing. It still was cooling, Kind of amazing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwcar Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2011 at 2:39pm
83Ski
Roym View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roym Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2011 at 12:10pm
Think I can get a few more years out of this one????
I have a replacement on the way, but this still pumped water. Bet it wouldn't of worked much longer. Even the fins that are still one piece are cracked at the base.
