74 skier windshield |
Posted: December-13-2011 at 1:41pm |
I believe so, yes. No grinding needed on them either... plug and play. |
Roym
Senior Member Joined: January-10-2009 Location: Odessa ,Florida Status: Offline Points: 129 |
The toilet bolts are also brass I believe. Are the ones on Ebay stainless?
storm34
Your local home improvement store should have these (toilet bolts) which work just fine and they're cheap. A few of mine needed a bit of modification to fit into the frame but nothing a little grinding couldn't fix.
gugi55
Newbie Joined: December-03-2011 Location: Hewitt, NJ Status: Offline Points: 26 |
Thanks that at least puts me on the right track !
The windshield frame is held down by t-bolts. Take a look under the deck and you'll see them coming through. Pop the nuts off and the windshield will lift right off.
The bolts will probably be in pretty rough shape... in which case, you may want to grab some new ones on ebay- its the only place Ive seen them available. ebay t-bolts |
gugi55
I have a 1974 skier 16 with a glass split glass windshield with glass wings and i want to remove it so i can redo the dash. any suggestions on how to remove the windshield. I am currently restoring the boat for next season. i don't want to ruin what i have !
