  New Posts New Posts RSS Feed - 98 Martinique - Oil Drain or Need an Extractor?
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Topic: 98 Martinique - Oil Drain or Need an Extractor?
    Posted: March-08-2012 at 3:06pm
Pete you've set yourself up big time with that reply for a Hollywood quote!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2012 at 3:00pm
Greg,
Just as Tim mentioned, I suck the oil out via the dipstick tube. On the Y block, the tube goes all the way to the bottom of the pan so I just use the large hose and the small rubber "coupling". The Tique I need to slip the nylon tubing down the dip stick tube. With the Atom, it's dip stick tube is about 1&1/2" ID so no problem getting a big tube down it. Then. I pull the inspection cover off the trans and suck it. I typically can get almost an extra quart of engine oil out of it.
crobi2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2012 at 12:42pm
Last time I changed my oil I took the cap off of the drain hose, went to the hardware store, got a barb fitting that fit the end of the drain hose and the largest hose from my vacuum pump, hooked it up... and pure happiness!
C-Rob
2000 SAN
Slupe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slupe Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2012 at 11:27am
Thanks Pete.   I have been lurking the site while looking for a boat and I picked up lots of good information.   I should have a diary soon and will be asking lots of questions once I get the boat.
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2012 at 11:03am
Originally posted by BuffaloBFN BuffaloBFN wrote:
Where do you pull it from Pete? I can't think of anywhere on the pumpkin where I could get a drain line in.
I like my oil drain line. Works fine with warm oil.
Gotta pull it from the dipstick, Greg. I do this on my Skier, and its a PITA. The oil drain hose works MUCH better! With the thick oil we tend to run, gotta do it warm, thats for sure.
Pete must have that threaded dipstick tube? Merc style? Fess up Pete!
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2012 at 10:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-08-2012 at 12:29am
I have a fitting to connect my pump to the drain hose
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2012 at 11:05pm
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2012 at 10:28pm
Andy,
Many have found that the "oil drain" hoses are more of a "gimmick" than anything. I have one on my 77 and never use it! It simply takes too long due to the small diameter of the hose. I just like I do with my other boats simply suck it out with the vacuum extractor. It works for me!
Welcome to CCfan! It's great to have you as a member but please do submit some pictures as well as so text for a diary entry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slupe Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2012 at 9:03pm
Sorry - it is an 1988 - that was a typo! Thanks for the info, I will have a look.
Jllogan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2012 at 6:50pm
a 98? you sure thats right? Do you mean an 89?
It will most likely have a little hose coming off the drain in the oil pan. Just run that out your bilge plug hole, uncap and drain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slupe Quote  Post ReplyReply Direct Link To This Post Posted: March-07-2012 at 6:49pm
Hi all - I just purchased a 1998 Martinique BR that I pick up later this month.   The first order of business is to do some routine maintenance including oil change, tranny fluid change, etc. From my searches, it sounds like you extract the tranny oil, but I'm not sure if I need to do the same for the engine oil or if there's a drain. Does anyone know if one is on this boat or what should I be looking for?
