  New Posts New Posts RSS Feed - help removing the ski ring
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Topic: help removing the ski ring
    Posted: April-04-2012 at 7:48pm
I think he's still active, but I don't know how big an operation he is. He was just on this thread, as they have a new retractable product for Super Air Nautiques:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=25046
hoggjaws View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hoggjaws Quote  Post ReplyReply Direct Link To This Post Posted: April-04-2012 at 7:38pm
I tried to order one of the sdbm and couldnt online. Then I called and left a message on Monday and have not heard back from the company. Has anyone ordered from this company?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2012 at 7:03pm
Originally posted by Bri892001 Bri892001 wrote:
Are those Super Deluxe Boom Mounts pretty solid?
If they hold tight and do what they claim, that seems like a really good option.
LOL, solid is a fitting description. Theyre solid aluminum and are NOT light weight! Super simple design and top notch materials... highly recommended.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2012 at 6:59pm
Don't have one but I've never heard anything but positive comments about the SDBM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2012 at 5:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2012 at 3:36pm
Pete, I knew you were going to post this.
I didn't need to go as far as making the ATF brew but I did use that on a stubborn old snowmobile secondary this winter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2012 at 2:53pm
Originally posted by hoggjaws hoggjaws wrote:
i am going to get a can of pb blaster and try that. if that does not work i may spring for the adapter.
Here's some data you may find interestig.
[QUOTE=8122pbrainard]
Get yourself some decent penetrating oil like Kroil or mix up 50% acetone and 50% ATF. Throw the WD40 and PB in the trash. You have fallen for marketing "hype".
[QUOTE=8122pbrainard] Here's the list of torque requirments copied from the other thread:
Penetrating oil ..... Average load
None ...................... 516 pounds
WD-40 ................... 238 pounds
PB Blaster ............... 214 pounds
Liquid Wrench ......... 127 pounds
Kano Kroil .............. 106 pounds
ATF-Acetone mix.......53 pounds
I don't even consider WD40 to be a penetrating oil so that puts PB at the bottom for me. Kroil is a on line order only so when I was taking my 1927 Flexifour apart and trying to break the rusted pistons loose, I did pick up a can of PB. A week went by with no luck and then the Kroil came in. The next day after using some of the Kroil, all four pistons were loose. I ended up using the PB as a honing lubricant!
The home brew ATF and reducing it with a solvent is real interesting! I need to mix up a batch and give it a try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2012 at 2:41pm
I just shot in some PB in where the pins are tapped on them to vibrate in the oil and the pins tapped right out. Make sure you use the right size drift pin so you don't bugger up the pins.
Then I put a shot around the base of the finger vibrated it by tapping the side of the pole with the rubber handle of the hammer. After a couple shots like that I put the hammer handle through the ring and gave it a twist. I couldn't believe it when it moved. I just kept shooting in the PB while working it back and forth and vibrating then starting lifting while twisting and out it came.
DON'T put to much pressure on it when twisting it can break!
Post Options Post Options   Thanks (0) Thanks(0)   Quote hoggjaws Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2012 at 12:44pm
did you have to soak the pins up with pb or heat them up? i have tried to pound them out and they will not budge. i am going to get a can of pb blaster and try that. if that does not work i may spring for the adapter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-02-2012 at 9:23pm
Just did mine this morning... Took about 10 minutes I was surprised to say the least.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hoggjaws Quote  Post ReplyReply Direct Link To This Post Posted: April-02-2012 at 4:18pm
thanks guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: April-02-2012 at 4:07pm
More info...
since this just came up a few days ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-02-2012 at 3:34pm
It's held in place with roll pin(s) or some call them spring pins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hoggjaws Quote  Post ReplyReply Direct Link To This Post Posted: April-02-2012 at 3:26pm
can anyone give me advice on removing the ski ring? i thought i could use an allen wrench, but after cleaning it out that is not the case.
