  New Posts New Posts RSS Feed - Stuffing box gone amuck
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Topic: Stuffing box gone amuck
    Posted: April-14-2012 at 2:07pm
key point, wheel speed is about 400 rpm at WOT because of the reduction
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 2:04pm
Pete, no need for dowel pins on the couplings because of the fitted bolts, they hold a .000 clearance fit, normally if you have some mis-alignment at the couplings the bolts will not come out...up in the engine room it took a few light taps to get all the bolts out and the couplings didnt seperate, which tells me for now she is pretty good on the alignment up there, I really can see the 30 ft shaft as being the problem at this point because the port Aft bearing is worn at the 5 oclock position and the starboard is worn at the 7 oclock, the forward ones at the trans end are perfect. some history on the shafts are the are supposedly forgerd steel not stainless, they have been welded up twice at the bearing areas...i really think the shafts are just whooped....they think alignment, they are worn evenly on both sides from the prop torque, they spin out board, they are the original shafts, i really think they are experiencing the paprclip effect
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 1:14pm
yep, no pilots, all fitted and reamed bolts, including the rudder bolts which i had to weld a 1" nut to each of them and pull with a porta power, they wanna pull that 18 footer which will be a 4 day project, this stub shaft has welded flanges and is tweeked about .012 over the 18 ft run, they want to cut up the boat to get her out because of its length and flange size, it was put in when the boat was built...smart ass me of course suggested, why not cut the old one out without cutting the fck outta the boat, manufacture a a tapered keyed shaft at both ends with seperate couplings, slide the shaft down the prop tubes and install the couplings????? thats why I get paid the big bucks   lol, they are starting to catch on lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 12:32pm
Eric,
You are correct - they had better drop that thing in the water before the laser guy goes to work!! I think you had better talk with him. He sounds like a pro with the shaft alignment using the laser. If so, he'll understand immediately.
No pilots on the couplings!!! I wonder if the were aligned, bolted down and then drilled/reamed for dowel pins for the alignment?? What's on them for the alignment?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2012 at 11:19am
I find myself going round and round with these Alabama ship mechanics, they gotta 18" jack or stub shaft sitting on two pillow blocks up in this ferry that runs to the 30 ft main prop shaft, so we have almost 50 ft of shaft, and now they are flying in a laser guy, was pulled in the office already and asked who i worked for and replied "for my family" oops.. then who signs your paycheck? lol
Im just fcn curious on how you can run a laser line on a 50 foot run on a 55 year old sagging boat up on cribbing...and to date no one has asked me about the pilotless, fitted bolt couplings up in the boat?
This yard was never really into ship repair, more of a pull tug company untill they purchased the travel lift, so far though I enjoy working there, more stories to come
Foot_Fungus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Posted: April-11-2012 at 1:41am
Picked up all the parts from skidim this afternoon and got everything tore apart. Decided to go ahead and do the strut bearing while I had it apart. Found a new way to remove the bearing after cussing at the hacksaw for 20 minutes. Turns out a 13/16" impact socket will fit in the strut perfectly. Lubed it up and tapped the bearing right out. Then used a punch to knock the socket back out. Literally took me 5 minutes. rubber was in the beginning stages of dry rot, but wear pattern was normal(had a little vertical play but no side to side). Not sure if its the original but it was a single piece 4" brass outer/rubber inner bearing.
Turns out instead of repacking the stuffing box the PO just kept tightening down the cap. The lock nuts was bottomed out and took some finessing to get off. Pulled it apart and found the below material. Only 2 rings and the 2nd looked like it had been combined from leftover pieces. The material crumbled in my hands.
Put a dial indicator on the shaft and she's straight and true. Only real issue I had was trying to get the stuffing box loose on the rudder. Pulled the rudder off just fine and decided since the thing wasn't leaking I would leave it alone for now. Sucker is corroded on there and I'm betting its the same issue as with my shaft box. And to the CC factory people, seriously why on earth did you put the pitman arm clamp bolt on the rear of the clamp instead of facing the front where it would of been easy to get to.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2012 at 10:36pm
Check the key for fitup before you have a 400 degree coupler in your hand. That was a problem for someone else recently.
Great job cutting it off, you must have a steady hand. The parting wheels make me nervous!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2012 at 9:38pm
After you clean up the shaft, make sure it's not fretted to much by measuring it. Erik mentioned it besides myself. You should have about a .000" to about .0005" interference fit.
It would also be a good idea to check to make sure the shaft is straight both down it's length but also just behind the strut on the prop taper.
crobi2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2012 at 9:22pm
Congratulations! Awesome job getting the coupler off without damaging your shaft. I would lightly remove the surface rust from the shaft. Make sure Vince gives you a new key that fits the coupler. Also check it on your driveshaft to make sure everything is going to go together smoothly. Don't forget to block the prop end of the shaft so you have something solid to push against when you slide the coupler on.
Watch Pete's video on shaft alignment if you haven't gotten to see it yet.
C-Rob
2000 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2012 at 9:01pm
After 2 hours, 3 chisels, and a 4.5" cutoff wheel the coupler has seen its last hoorah. Ended up slicing down the key on one side and then notched the 180 degree opposite side. Used the chisels to pry it open like a clam till the non-key side closed back up, cut another notch and spread it a little more. Took 3 notches and a slow pace, but it came off without damaging the shaft. Though the key is toast.
Dropped by SkiDIM and spoke with Vince today and he agreed to give the coupler hell since I really had nothing to loose. They have a coupler instock probably still on his desk that I'll swing by tomorrow and grab. Now I just need to do some searching for a how to on putting it back on. From what I gather I heat the sucker up for 30 minutes then hot potato it onto the shaft. I'm just curious if I should clean up the surface rust on the coupler end of the shaft or leave it be. The boat has 900hrs on it so I'm thinking I might as well do the strut bearing while I have it off. Just means I won't get to get back on the water this weekend :(
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-09-2012 at 8:44am
just call and tell them what you have, ask for tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote crobi2 Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2012 at 10:42pm
I also think you should just toss the money at it and use an A.R.E. system shaft. I have pictures of the shaft and also a picture of my old walter's style 3 1/2 in coupler on this link:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=24811&KW=&title=replacing-cutless-bearing
I also read somewhere that if you are going to split your old coupler lengthwise, use a cutoff wheel and cut it right along the keyway slot.
Of course, I think Eric is also right about just cutting the shaft off with the cutoff wheel and being done with it.
It will be worth the money to do it yourself and then be able to take the shaft out at will.
Check your cutless bearing and go ahead and do it too if it's ready.
C-Rob
2000 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2012 at 9:48pm
no ***************, that would be the cats meow. I was gonna cut the coupler, then go buy a regular coupler and bake that sucker and do a 'hot potato' install, but if that split coupler will work just as well that seems worth a few extra bucks... Heck its still gotta be cheaper then a new ARE shaft. Anything special they'll need to know or just a 4" flange with a 1" ID keyed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2012 at 11:57am
if you do slice, you can get a split type walters coulping that will clamp on the shaft, that's if the shaft is straight and the end isnt fretted, 800-462-8848 TMI carries the split type 4" flange 1" shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2012 at 11:44am
Steve, still waitin on you to send me his contact info.
Boat Dr. in my post above I had already ruled out the 'shade tree' repair, all I'm currently debating is slicing apart the coupler or the shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2012 at 11:16am
all relevent
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2012 at 11:15am
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2012 at 10:37am
personally i think it's the bearings causing the problem or they have welded the shafts in the past and they have the paperclip effect
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-08-2012 at 10:35am
Pete, just to let you know, i was cutting out phenolic bearings, i brought my chain saw in, worked very well, its a whole new ballgame with these big bastards, looking from the back of the boat the port was worn down to the metalat the 5 o'clock positon and the starboard was worn at the 7 o'clock...alotta armchair qauterbacks....not one of them yet got up in the boat to ask about the alignments yet...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 5:06pm
Originally posted by SNobsessed SNobsessed wrote:
Originally posted by gtxragtop gtxragtop wrote:
took 220 sandpaper and cleaned out the bit of corrosion in the coupling. Was not much to remove. It then slipped right on/off again like butter.
The coupler needs to be a press fit. If it slipped back on to the shaft without heating, the shaft may come loose under load.
NG,
Chris is correct. You have a problem just waiting to happen.
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 4:12pm
First we learn, then we learn to do it right.....
Any halve assed repairs below waterline are indeed STUPID...
Either remove the engine or cut the shaft...
This is not that hard a repair, why not do it correctly ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 3:24pm
if you opt to cut the shaft, use a cut off wheel, dont mess around with a swazall....5 minutes, really, what happens if you spend the weekend d*cking with the set screws only to find out the shaft is whooped? the ARE is the way to go
Swatkinz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Swatkinz Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 2:58pm
Option 4....Call GZ and get him to take care of it. I think that'll be the most cost and time effective option and it'll be done right.
Steve
2011 Sport/Air 200
Excalibur 343
2017 Boatmate Tandem Axle Trailer
Former Malibu owner (07, 09)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foot_Fungus Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 1:47pm
Ok So after doing some research I'm down to 3 options. I ruled out the rubber hose patch idea bc its just not worth the risk, and I'd constantly worry about it.
1. Drill out the set screws and then tackle popping the shaft out of the coupler. ($5, but will probably take a weekend after all is said and done)
2. Slice the coupler long ways and just buy a new coupler($85 and about 2hrs to slice through it)
3. Cut the Shaft and buy an ARE double taper($450 and 2hrs to cut through SS)
SO now I just need to evaluate how much my time is worth and if Id rather waste money or waste my time. This also would drain my ACME 422 prop fund. Not even sure #2 is possible, just an idea I had that it had to be softer than SS. #1 may backfire as this boat was in salt water for about 2 years so I'm thinking the coupler may be a solid block of rust. I'd love to hear other people's thoughts on the matter.
On a side note after noticing brand new shiny engine mounting bolts where everything else is dirty/rusty it appears this sucker had a new engine put in or atleast, which would also explain why it says EFI on the side of the boat but has a newer carb on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 1:09pm
Originally posted by M3Fan M3Fan wrote:
Maybe drill out the broken set screw, then proceed with the PITA process of removing the coupler, then re-tap for bigger set screws? Other than that, sawzall and new double-taper prop shaft?
+1 on this one. Lot less work involved then pulling the motor out just to get the shaft out and a heck of a lot cheaper than buying a new shaft. I know there is a thread here somewhere where Fans used a ATF/Acetone mixture (?) with great results instead of PB blaster etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 12:18pm
gtxragtop View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gtxragtop Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 1:33am
You will need to drill out the set screw. If your lucky, it will then come out with an EZout. If not, then you will need to buy another coupler. I just when through this on my 96 ski nautique. I soaked the shaft/coupler with PB Blaster for 3 days. Added heat, tapped with a hammer with no luck. I then mounted an automotive harmonic balancer puller on the coupling and heated the coupling up with a blow torch. It moved very slowly and I needed to keep the coupling hot. It finally came of. Replaced the packing and took 220 sandpaper and cleaned out the bit of corrosion in the coupling. Was not much to remove. It then slipped right on/off again like butter. Amazing what 10'thousands of an
inch of corrosion will do. I though that I would put it together with
anti-seize but then thought... Bad idea, I don't want movement. Used one of these tightly mounted to the coupling.
http://www.google.com/products/catalog?hl=en&sugexp=frgbld&cp=18&gs_id=39&xhr=t&q=harmonic+balancer+puller&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&biw=1400&bih=858&um=1&ie=UTF-8&tbm=shop&cid=3562934389496767239&sa=X&ei=S6d_T_2ML4H30gHVi9zbBw&sqi=2&ved=0CG8Q8wIwBA
1996 Ski Nautique GT40
Worcester, MA.
bfedio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bfedio Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 10:44pm
Damn I'm new to this forum, but joined because I need to tackle the packing in my 97 super sport. Just looking at where it is, thought it would be nice if it could slide out the bottom to access. guess i'm goin in. I'm the only owner and have never had an issue before. noticed the past few year it took on more water over night. Now the bilge cant keep up. figured I'd do the drive shaft and rudder. any tricks??????>
grim007 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grim007 Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 10:42pm
at work we use the repair until we need to remove everything last resort kind of thing
shaken not stirred
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 10:23pm
You could hoist up the engine & pull the shaft from the inside. would be extra work but cheaper than a new shaft.
