  New Posts New Posts RSS Feed - Fuel tank replacement
mackwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mackwrench Quote  Post ReplyReply Direct Link To This Post Topic: Fuel tank replacement
    Posted: October-03-2005 at 5:51pm
Sweet.....
NO LONGER A MEMBER
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2005 at 5:24pm
I replaced the Tempo metal tank (long cruise) in my '66 Mustang this summer. This is the plastic Tempo model No. TP18SC, part No. 640061. It is 46 3/4" L 10 1/4" W and 10" H. It fits perfect. The only difference in the original is there's no flange on the ends for the hold down boards and the pick-up and vent are not exactly in the same place, but the spout where fuel pours in is in the same place. I had to buy slightly longer lines for the pick-up and vent. You need to get a hose with a formed 90 degree that is 36" long for the vent because it's tight above the tank. In the photo above, you can compare the two tanks. Both are 18 gallons.
Tim D
