2002 super air front bow wrap-around cushion |
mike32
Groupie Joined: November-27-2011 Location: lanc, ohio Status: Offline Points: 66 |
Posted: April-27-2012 at 12:52am |
Yes there ared screws under the dash and windshield. Then there are clips that it slides down through on the sides. I couldn't get the whole thing out but I had the aft section loose enough to replace the speakers. thanks.
lewy2001
Chopper mentioned last post in Bow Insert thread that his 03 SAN had bolts under the deck near the windscreen instead of the screws. Not sure if they still used the screws at the bow but hard to see how you could get access to the rear of that part of bow cushion insert.
Like Rob mentioned please post pics of what you find. |
crobi2
Senior Member Joined: April-05-2011 Location: Texas Status: Offline Points: 112 |
I followed all of the threads, it sounds like a 2002 SAN may have some through bolts (at least aft if not also at the bow). PLEASE post pics when you get it loose, thanks!
C-Rob
2000 SAN |
lewy2001
mike have a look at this thread I doubt that it has changed that much from a 98 model.
Bow Cushion Insert |
mike32
Are there any bolts in it at all?
Christine's has them. They sometimes only work once. |
mike32
Anyone have any thoughts on how to remove this thing. Is it bolted or does it snap in?
