  New Posts New Posts RSS Feed - carb adapter
carb adapter
hotboat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Topic: carb adapter
    Posted: June-04-2012 at 12:23pm
Now I see, appears you would need 2 of the edelvrock plate unless you can run your spacer upside down or else eliminate your spacer and just run edel plate
Brian
birdiebertus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote birdiebertus Quote  Post ReplyReply Direct Link To This Post Posted: June-04-2012 at 12:17pm
oke
and what is then sealing of the carb? look foto 4!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Posted: June-04-2012 at 12:12pm
Intake, gasket, edelvrock plate, gasket, your spacer with the open side down because that's what the edelvrock plate seals off, gasket, carb. B not v dang phone!!!!
Brian
Post Options Post Options   Thanks (0) Thanks(0)   Quote birdiebertus Quote  Post ReplyReply Direct Link To This Post Posted: June-04-2012 at 10:44am
now i dont no what to do i tink it is first gasket,spacer,gasket,plate adapter,gasket,carb!!!!
65 'cuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2012 at 11:40pm
The adapter is plate steel, install: gasket, plate adapter,gasket,wedge plate, gasket, carb. There is not enough surface area at the intake manifold to get a good seal with the holley pattern, the plate adapter solves this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote birdiebertus Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2012 at 9:59am
oke thanks
do i need a open spacer olso or is it posebble to juse the wane i have.
sorry for my bad engels
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2012 at 9:56am
Edelbrock part # 2732
Brian
lewy2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2012 at 9:55am
You need this
adapter
89 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote birdiebertus Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2012 at 9:11am
oke but this is wat i have
intake manifold.
this is my spacer.
if i put the spacer on my carb i have a gab and i tink it gets false air
by the screwdriver.
this is my carb.
ho can help me i tink i need a adapter or so.
sorry for my bad engels.
Hooty222 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hooty222 Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2012 at 1:49am
Thinking preformer manifolds can fit both square bore (holley) and spread bore(Q-jet's and holley spreads) no adapter unless PVC needs a vacuum source
1986 Ski nautique 351
1988 Barefoot nautique 454
Post Options Post Options   Thanks (0) Thanks(0)   Quote birdiebertus Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2012 at 8:02pm
i have a edelbrock performer intake manifold and a holley 4010 marine carb what carb adapter i need to make it fit.
