  New Posts New Posts RSS Feed - Electronic Ignition Kits!
84starsandstripes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 84starsandstripes Quote  Post ReplyReply Direct Link To This Post Topic: Electronic Ignition Kits!
    Posted: July-27-2012 at 11:09am
Accidentally ordered one for a Cleveland!!!!! Thanks for the info guys, working on getting a new one for the Windsor now.
Gary, thanks for sending that DUI system over, I might have to check that out.
1984 MasterCraft Stars and Stripes
PCM 351
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2012 at 12:51am
It sure looks like you got a distributor for a 351 CLEVELAND not a 351 Windsor.
If I remember right the Windsor gear is about 1 1/4 inches in diameter and the Cleveland gear is about 1 4/10 inches.
The 351 Cleveland also fits the 429 and 460 engines. The 351W fits nothing else.
You should be able to get Pertronix to exchange it or give you the right gear to make it work.
Ken O
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2012 at 3:42pm
I didn't realize you were going to change the whole thing,I thought you were just going to get the points replacement. Since it doesn't fit it's your chance to return it and go with a D.U.I system recommended by others in the know here.
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2012 at 2:11pm
I wouldn't think it would be able to fit with the bigger gear on there... The circumference of the gear would have to be the same.
Something is wrong, but not sure what. I'm sure someone on here would know what motor the bigger gear goes to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 84starsandstripes Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2012 at 1:50pm
Need some help!
Alright guys, I went to toss in my Pertronix Distributor today and had some issues going in. Towards the end we saw what we think was our issue when we went back in with the original but before I try again I wanted to check with you guys first.
I double checked the Pertronix part number and it seems like I definitely have the right model! I went to toss it in and the spline at the bottom looks bigger than the factory. If any one has experience with this distributor, is it supposed to be like this?
PCM 351
Post Options Post Options   Thanks (0) Thanks(0)   Quote 84starsandstripes Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2012 at 6:35pm
Originally posted by Waterdog Waterdog wrote:
E spark (mallory) seems to be the best. Thats the one i use (86 2001).
My brothers (Pertronix) was bad out of the box.(84 2001)
When you mount the new coil try not to "lay in down" 30* angle or better.
My friend has a baby blue and white Stars & Strips. Where C/C guys here But thats a NICE boat!
Thanks for the info, we'll see how this unit works out! When you talk about the coil, is the stock coil bracket at that angle or should I adjust it?
I definitely am a Nautique fan, I absolutely love the 2001's but this hull was entirely too clean to pass on.
Thanks for the kind words and information everyone!
PCM 351
brittcrowell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brittcrowell Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2012 at 2:37am
Nice Nasty Raft
'93 Ski Nautique (needs new interior)
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2012 at 12:48am
An oil filled coil will overheat when on it's side.   There has to be some air inside the can to allow for thermal expansion (not completely full of oil). When you lay it on the side, some of the windings are not immersed in oil & don't get cooled.
Did you get the EST dizzy?
Lakeview View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lakeview Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2012 at 12:31am
MSD makes an epoxy filled vibration proof Flame Thrower coil that I've recently installed-excellent product and great spark-The oil filled coils are not designed for the marine environment,but all of the older boats came with them.
Lakeview
1992 Barefoot Nautique
1967 Barracuda SS
1967 Chris Craft Cavalier
Mick88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mick88 Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2012 at 12:23am
Why is this a good idea?
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2012 at 11:20pm
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 84starsandstripes Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2012 at 6:26pm
Mike,
You will have a second small terminal on the starter relay. When it's energized during cranking, this is wired to the coil by passing the resistor and providing full voltage to the coil. However, now that you have ordered the conversion, follow the instructions that come with it.
Thanks Pete, we'll see how it goes!
PCM 351
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2012 at 4:53pm
Originally posted by 84starsandstripes 84starsandstripes wrote:
Originally posted by GottaSki GottaSki wrote:
I concur with Pete
Without the bypass, the coil enerize is further pulled down by the undersized, aging wire from the dash, the alternator energize, and the electric choke. Plus the ballast and drop from the starter, its a wonder they start at all.
Very nice boat!
Before spending the money on a EI conversion that are prone to problems (yes, I'm one that doesn't believe in them) why don't you check to see if your engine is equipped with the ballast resistor bypass during cranking.
How exactly can I look for this to confirm?
Regardless, I do want to check the ballast resistor that you're talking about though.
Mike,
Post Options Post Options   Thanks (0) Thanks(0)   Quote 84starsandstripes Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2012 at 4:45pm
Originally posted by bhectus bhectus wrote:
Nice find, I really love the look of those old stars & stripes in the water.
Thanks, definitely looking forward to dropping her in soon.
I concur with Pete
Very nice boat!
New plugs will be going in today and I ordered an EI Conversion with Coil and an entire distributor from Pertronix. I figure I'll keep the original Prestolite in the boat incase anything happens!
PCM 351
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2012 at 1:59am
I concur with Pete
Very nice boat!
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2012 at 7:58pm
bhectus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhectus Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2012 at 6:41pm
'87 Barefoot - sold
'97 Super Sport Nautique - originally custom built for Walt Meloon
'97 Ski Nautique
'83 SN 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote 84starsandstripes Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2012 at 4:40pm
How's it going guys!?
I just picked up a 1984 MasterCraft Stars and Stripes and I'm looking to improve the starting of it. On both Correct Craft Fan and the Mastercraft forums it seems like people either love the kits or hate them.
I'm more than likely going to give a kit a try so I just wanted to see which kit everyone here likes. Seems like the Pertronix kit is popular but I do see the Hot-Spark kit appear every now and then.
Aside from that, any recommendations on getting this running perfect?!
Any experience with these guys?
http://www.nationalcarburetors.com/marine/fourbarrelholley.aspx
Some Pics:
PCM 351
