2001 GT40 - Remove RWP when winterising? |
Post Reply | Page 12> |
Author | ||
east tx skier
Senior Member Joined: August-22-2006 Location: Tyler, TX Status: Offline Points: 248 |
Posted: November-15-2012 at 3:38pm |
A little late on this response, but if you are going to "drain only" and not add antifreeze, I'd suggest, after draining, you
(1) pull the safety lanyard and crank for a couple of seconds. Like you suggested, this will get some of the excess water out of the pump housing. However, given the orientation of the pump on the PCM engines, I don't see nearly as much water expelled as I did on my old Indmar. Probably not necessary, but old habits die hard. (2) tow your boat around for about 5--10 minutes, over some small hills if available. If there is any water in the nooks and crannies of the cooling system, this can get it to drain. Don't believe me, leave your bilge plug in and see how much gets collected. (3) leave your plugs out until spring. I did this method with no problems at all. The only reason I use antifreeze on my Correct Craft is because (1) it's so easy to pour it in and (2) for whatever corrosion protection it might offer. |
2001SAN
Senior Member Joined: June-26-2012 Location: Ireland Status: Offline Points: 246 |
ok. bump once to drain rwp. cool. thanks again fellas - and lady!
darren. |
A little knowledge is a dangerous thing...
2001 Super Air Nautique 1989 Fairline Corniche 31 www.bannrivercruises.co.uk |
Guests
Guest |
So 50/50 is half funny-?LOL! boys will be boys--Linda!
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3896 |
LMAO Good one Gary. |
Guests
Guest |
LOl- just me being me-lol---just having a real hard time posting any pics..{ dots this tim}LOL
Hollywood
The poster using all the dashes and equal signs.
Guests
Guest |
Who are you speaking to holly?
Hollywood
What is with your random use of characters?
You would only need to bump the engine once to get the rwp spun around and emptied. |
Guests
Guest |
that 0r open the nut under the elbow----Linda-- or dump AF//Best to keep the fins wet..u boys like it wet right?lol--Linda!
Guests
Guest |
Just add some Af- take the hose off and dump== Keep the fins on the raw pump in Af over lay -up--Linda!
2001SAN
ok - thanks all. i think i'm good to go.
say i don't fill with AF and there is a little water in the RWP. I could purge this by running the engine for a few seconds after draining? darren. |
TX Foilhead
The Walters V drive cooling is just a few offset fins that the water flows around and it sits on the top of the unit. You should be able to get the water out by dissconecting the feed and return lines on the front of the motor and letting them drain. Easier than pulling the seat and floor of you aren't going to change the oil. If your going to do antifreeze be sure to put it in by the strainer so it will circulate through the v drive.
GlassSeeker
Grand Poobah Joined: November-26-2008 Location: Elk Grove, CA. Status: Offline Points: 2421 |
I seriously feel sorry for you folks that have to winterize your boats.
Winterizing mine means remove the bimini, take the ice out of the cooler and put in warm water, put the drysuit and fleece and uggs in the skibag. |
This is the life
Drain and put the anti in. Linda, I agree with Tim that you have been very lucky. Have you ever bothered checking the freeze protection wit a refractometer? Even then, the sample point may be fine but you may have a pocket without decent protection. I've got 15 years on your 30 and even put in time winterizing at a CC dealer. I NEVER RECOMMEND WINTERIZING WITHOUT DRAINING. Then I don't really care how you get the antifreeze in but pouring is simple. Why are you screwing around with pumping it through the engine???
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21185 |
The path to fill the block (in the thermostat housing) is always open... and this is why the block can be filled even when the thermostat is closed. However, if the block is already full, and the thermostat is closed, the fluid in the block has nowhere to go, so no new fluid being introduced via the thermostat housing can enter. Instead, it gets dumped out the exhaust. The fluid in the block remains static until the engine is up to temp, at which point the thermostat opens and allows it to exit (intake-->stat housing-->exhaust-->out the back of the boat), and the engine again fills with cool new water supplied to the stat housing (from the RWP).
If water was constantly circulating through the block, then the thermostat would serve no purpose and the engine would never come up to temp. |
Guests
Guest |
TrBenj---- I guess,,,Question is doe not the impellar creat a full flow through the entire engine-- block ;too? Ty again--I have no problem with your system,,u seem to like to help-and that makes this site worth its salt-- ...
No, the PCM Ford cooling system is amongst the most basic and my points above were most applicable to it. Its a great system- very easy to troubleshoot and runs very consistently. Its also very easy to maintain- surely your research has turned up the engine manual that describes the proper winterization process (ie, drain and fill)?
Guests
Guest |
Thanks Trbenj. for your time-Your points are well taken. I have PCM marine,351 windsor,1986...from my research they clam that it is a full circulation bypass system.permitting a full flow of water through the system,even during warm ups.Impeller,keeps the system full.Does this change anything? Key words{throgh the enire engine} as per the manual.
M3Fan
Just draining alone is fine if that's what suits your fancy. I've seen boats done each way for decades and they are fine either way.
MI-nick
Gold Member Joined: January-12-2009 Location: Ypsilanti, MI Status: Offline Points: 810 |
'01 should be a walters...should have 2 square head plugs near the top of the unit on opposite sides.
As far as I can tell, I'm not quite sure...
hotboat
Gold Member Joined: March-28-2009 Location: Conn Lake Pa Status: Offline Points: 814 |
What kind of vdrive? Not being smart, had a Walters and only ever pulled the hose. Wasn't aware of any plugs |
Brian
MI-nick
don't forget the two drain plugs on the V-drive.
i always pour in AF...only need 2 gallons vs. 6 for the run through method...and pouring in is easy... |
phatsat67
I loosen my belts during off season and I detach all hoses to make sure water is not sitting anywhere. When I do that I hand rotate the RWP to get any water left in the housing out. Spring Means new Impeller for me this year. Gets about 180 at idle after a long WOT run. Thats my indicator.
2001SAN
didn't mean to start one of these! i will be draining - no question either way. just not sure about filling with AF yet. some years i do, some i don't. the times when i don't fill i pour AF through until it runs out the plugs or hoses, then put it all back together. 3 gallons of AF costs about £50 (about $80) and i know loads who just drain and leave it at that. this will be my first year winterising my super air - all my experiences are from my previous boat. thoughts? |
hotboat
If you do not drain, after you run your 5 gal of antifreeze pull the block plugs and check color, better yet capture in container and test. As Tim stated it will be somewhere between straight water and a mixture depending on thermostat
Brian
This whole conversation is a moot point if you use some of that good old -100 antifreeze
Lucky? Yes. In most simple cooling systems, there are 2 basic paths fluid takes through the motor. They are: 1. RWP-->thermostat housing-->circ pump-->block-->heads-->intake-->thermostat housing-->exhaust manifolds-->out the back of the boat 2. RWP-->thermostat housing-->exhaust manifolds-->out the back of the boat The thermostat controls the flow out of the engine. If the thermostat is open, water will follow path #1. If the thermostat is closed, fluid will follow path #2. Unless you remove the thermostat or intrinsicly know it was open (no idea how you would do this), if you do not drain the block, you have no way to determine which path the antifreeze took. It is entirely possible that it took path #2, and the block remains 100% full of water. Its also possible that its full of antifreeze, or a water/antifreeze mix of anywhere between 0% and 100%. If you are using marine/RV antifreeze, you know that it is not meant to be diluted, so anything less than 100% antifreeze offers diminished freeze protection. So, like I said, without draining first, you can have no guarantee as to what % of antifreeze is in your motor, nor if it is sufficient to prevent a freeze. That is not the type of gamble I take with my boats, as draining takes about 3 minutes... but YMMV. |
Guests
Guest |
LOL--75-I hear ya....
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6130 |
Linda,
I am fine with your method and did it that way myself for many years, well maybe not quite, I think I drained first. But anyway, your first winter here, you didn't realize that this discussion comes up every year and there are those that say, don't drain, just pump through. Then there is a very large and vocal group that says that is bad, that without draining there is residual water in the block that remains there, even when pumping through AF, that can freeze and bust a block. There is one member that provides an accound of a cracked block using that method. But then there are a number of members that report "well I've done it that way for years and its always been ok". So my comment was just implying that you may have started that discussion up again, which is always good for getting a comfy chair and a bag of popcorn and watching. "my weekend was great, thanks for asking" (still skiing comfortably down here....which has been a pleasant change this year, having just moved from 22 years in NY and then MA) Where in NY are you? EDIT: Tim posted while I was typing.... |
