Running boat on water hose |
ricofrancois
Groupie Joined: January-11-2013 Location: California Status: Offline Points: 52 |
Posted: February-07-2013 at 3:26am |
upgraded flush
Ski Nautique 97 - GT40 EFI
The valve is not needed. Many here have used Tim's set up without valving. The RWP will suck enough. When the engine isn't running, the water will go out the through hull pick up. One danger of the valve is forgetting to open it when you put the boat in the lake!! |
ricofrancois
@Waternut the boat was only in fresh water.
@8122pbrainard I agree with you, the T should be the other way around. I was thinking about adding a brass valve for easy flush and service. |
That is a swivel 3/4" GHT thread adapter on the plugged side of the tee. It was set up for running or flushing the engine out of the water. However, for better flow, I would have installed the tee so the supply of water is directed towards the engine and not the strainer and supply.
Waternut
Senior Member Joined: July-11-2012 Location: Macon, GA Status: Offline Points: 292 |
Most likely. Kind of looks like it's been run in salt water which would reaffirm the flush fitting requirement.
ricofrancois
Hi, I was wondering if the T fitting on my boat is for connecting a hose to run the boat off the lake.
