  New Posts New Posts RSS Feed - CONTROL ARM WITH LOCKOUT
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: CONTROL ARM WITH LOCKOUT
    Posted: February-24-2013 at 7:37am
Originally posted by phatsat67 phatsat67 wrote:
All I can order from Nautique is the full assembly.
Zach,
When N3 orders parts, is the PO addressed to "Nautique" or "Correct Craft"?
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: February-24-2013 at 3:17am
This came up last week too:
Lever
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2013 at 6:48pm
ricofrancois View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ricofrancois Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2013 at 6:41pm
Thanks it makes sense. The pin would be easy enough to replace but not sure the part alone exists. Is this arm made by teleflex? If so I will try them.
Ski Nautique 97 - GT40 EFI
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2013 at 6:02pm
Probably just a worn out roll pin or hole? I've never taken that style apart before. I'm sure someone has because the lock out pieces break.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ricofrancois Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2013 at 4:57pm
Hi
I replaced the transmission control cable on my 97SN196. The control arm was catching which caused bad pull up for skier and engine hesitation. Now with a new cable throttle control is smooth and a real pleasure.
My question is there is a silver pin on the control arm that is going through the lockout mechanism. This pin keeps pocking out when the lockout is used when driving. I push it back in by hand or with a screwdriver but it keeps moving out.
Any of you had this issue?
