Oil Filter Comparison/Evaluation |
Page 12> |
Author | ||
![]() ![]() ![]() ![]() ![]() Posted: May-13-2021 at 11:59am |
Time to trade the Mazda in for a VW TDI- your probably looking at 10 gallons a week
![]() Premium hit 399 here- other than price we can get any we want.
Morfoot ![]() Grand Poobah ![]() ![]() Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5331 |
It's freaking insane down here... I had a tick under a half which is enough to get me back to work from home (53 miles) but I'd have to stop on the way home to fuel up. Got off the highway 20 miles from home to take the back roads to find gas. I passed at least 12 and all were posting 0.00 on the signs. Got home and made the decision to use my 6 gal can of boat gas in the car as I didn't wanna burn a day of Vaca for this BS. Saw on Gasbuddy this morning that 50% of GA stations have no fuel but could be worse as 75% of stations in NC have no fuel.
This is a set up right Pete????? ![]() ![]() I said I use Motorcraft FL 1A and Valvoline VR-1 20w50 in both. Don't recall what he ended up using. I think Mobil filter which after seeing the table again I think I'll change to Mobil.
So Tim, what brand filter and what oil did you recommend?
Guess that's what happens Tim when you have time on your hands waiting in line for gas
I was just thinking about this thread the other day when my neighbor was asking what filter and oil SHOULD he be using in his 88' Elite Craft. I told him about the many discussions of oil and filters here but that was many moons ago.... Bam!!!! Here it is. Thanks for the post Steve.
boardersdad ![]() Senior Member ![]() Joined: June-18-2013 Location: Wisconsin Status: Offline Points: 409 |
I noticed the table images disappeared over the years. Here they are again.
With some part numbers...
OK, Steve K and I cleaned up a few technical details and have the oil filter grades.
These rankings are from the one referenced study only. We are assuming the individual category grades (filtering, quality, etc) are common across a manufacturer's sizes of a specific filter, because the part number used in the study is not necessarily the one for our engines. For example, the different Fram filters in the study are delineated by application ("High Mileage", "Racing", etc), whereas we're referring to different filter sizes within an application type. These rankings do not factor in price (on purpose). The updated table follows. Five filters get an A- or B+ for their final grade. There are a lot in the middle grades, and a lot in the low grades. I'm switching to Mobil 1 oil filters. Steve ![]() . |
We're cleaning up a few details, stay tuned.
skutsch ![]() Grand Poobah ![]() ![]() Joined: June-19-2008 Location: Racine, WI Status: Offline Points: 2874 |
This is essentially the logic train I used. Now that's not to say there is an error in one of my formula's...
IF(D4="A", 4, IF(D4="A-", 3.75, IF(D4="B+", 3.25, IF(D4="B", 3, IF="B-", 2.75, IF(D4="C+", 2.25, IF(D4="C", 2, IF(D4="C-", 1.75, IF(D4="D+", 1.25, IF(D4="D", 1, IF(D4="D-", .75, IF(D4="F+", .25, 0))))))))))) |
Steve, I sent you a PM, shoot me your email and I will send you my spreadsheet. Your formula above is essentially correct, I think the difference is how you value each letter grade and how I did.
I don't believe they were, the part numbers were as listed in the original study. Again, I did not complete the analysis, just reinterpreted the data. Yeah, this stuff is cool, there are plenty of us geeks here on this forum. Then even more fun is watching the arguments that flow from the analysis - HA! Enjoy! |
Steve K,
An excellent project, thank you. I have a question about your weighted averaging in your April-22-2013 10:29pm post. The best scoring filters are: FILTER: grade FILTERING/QUALITY/surface/volume K&N HP-3002: grade 3.88 B/A-/b+/a Fram Xtended Guard XG5: grade 3.81 A-/A/c/a Mobil 1 M1-302: grade 3.73 B/A/a-/a Wix (NAPA) 51060: grade 3.42 C/A-/b+/b+ Purolator Pure-one PL34631: grade 3.42 C-/B+/a-/b+ Look at the individual grades... The Mobil 1 B/A/a-/a is better than the K&N B/A-/b+/a, so the Mobil 1 should have the higher weighted grade, correct? I was unable to match the grades values you received. I assume you multiply the weighting times the grade, add, then divide by the weighting total (12). Example: Mobil 1: [5(3.00)+5(4.00)+1(3.67)+1(4.00)]/12 = 3.56, but you get 3.73. Am I miscalculating this? Another question: Are all the oil filter part numbers you list for the PCM 351W? I haven't looked any of them up. Thanks, I love this kind of study. I know, I'm a geek... Steve |
quinner ![]() Grand Poobah ![]() ![]() Joined: October-12-2005 Location: Unknown Status: Offline Points: 5828 |
I do LOL, the PCM Small Block Chevy's of the 2002's and beyond all use a remote filter, FL1A. Was hoping Motorcraft was not as bad as that report indicates. |
PAPA ![]() Senior Member ![]() Joined: October-06-2009 Location: Fremont, In Status: Offline Points: 202 |
Funny thing about filters, every part number is built different to different specs as specified by the engine manufacturer. Motorcraft FL-12, is not the same as FL-1-A, or FL-820-S, etc. Same thing can be said about the price, common filters like FL-1-A or FL-820-S are way cheaper and easier to find than a FL-12. Who buys a Motorcraft filter for a small block chevy? lol. One thing I can say about Motorcraft filters is I haven't had to warranty any engines due to one of their filters failing; while I have seen other brands of filters fail and cause catastrophic engine failure. I will continue to use the Motorcraft filters designed by Ford and built by Purolater on my Ford engines. They might not be rated the best but they have done damn well everywhere I have worked since 1969. Just my two cents.
Riley ![]() Grand Poobah ![]() ![]() Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7963 |
I use NAPA Gold as I have an account with them and buy most non marine stuff from them. But, I did use Fram filters for years including on my vehicles when I used to do all my oil changes and never had a problem with a Fram filter and most of my vehicles all went upwards of 200k or more. If you change your oil often or don't use your boat much, I don't think the filter makes much difference. What I have found though is on extended oil changes like I've been doing on my vehicles for the past 7 or 8 years is that some filter clog up faster and there is a noticable drop in oil pressure when you get beyond 10,000 miles on an oil change.
See Joe, you mechanical engineering types understand this stuff so much better then us electrical engineering guys. That one thermodynamics class we had to take really only wets the toe on the whole fluids concept/discussion. Excellent add on analysis.
Interestingly enough the old study (circa 2004, Bobistheoilguy.com) did some of the loading condition analysis, and they had results all over the place. As you stated the marine application loading condition is WAY different then the automotive. I wonder how much study the marine engine conversion folks have done on oil filters... |
JoeinNY ![]() Grand Poobah ![]() ![]() Joined: October-19-2005 Location: United States Status: Offline Points: 5698 |
I find some value in his construction evaluation but the filtration test doesn’t have any real value IMHO. It appears to be only a test of the flattened media at a subjective pressure drop. That doesn’t have much real world correlation to how well the filter would work. A small amount of highly restrictive media which would score well on this type of test would cause a very large pressure drop across the filter, which aside from placing more strain on the engine would slow down the overall oil flow rate through the engine (by causing the bearing surfaces to see less pressure post filter).
Additionally to me it seems using a vacuum to pull oil through the paper doesn’t simulate 14 psi of oil pressure but rather 14 psi of pressure drop in the oil filter.. which would be excessive. Most filters would be sending oil unfiltered through their bypass valve back to the engine by that point, 10 to 12 psi used to be a typical bypass pressure rating point back when I paid attention to such things. So the filtration media might be awesome, but if it restricts flow too much then all the oil is going to bypass it anyway, and if it filters very well but only at pressure drops it will never see then that also doesn’t help things. I don’t doubt that the high end fram filters are better than they used to be, but I would stick to tests that show pressure drop at reasonable flow rates through the filter assembly. Preferably at different loading conditions ( Ie how well does it filter after the first 1000 miles, and how much oil pressure does it rob while doing so). Personally, knowing how many rpms we regularly run our motors, I would say we would be better served by a bunch of relatively porous paper, than by relatively high filtration paper because at 3600 rpm I am guessing too much of the latter would have almost all the oil bypassing the filter element and returning directly to the bearings (particularily with you guys that run that 20-50w stuff). |
turningpoint84 ![]() Platinum Member ![]() ![]() Joined: September-11-2008 Location: Cincinnati, OH Status: Offline Points: 1467 |
M1-302 and i'll e done with it.
Proud 1968 mustang owner and now
1970 Mustang |
dwouncmd ![]() Gold Member ![]() ![]() Joined: July-10-2009 Location: NC Status: Offline Points: 919 |
Very interesting. It is nice to see critical thinking vs. marketing and personal anecdotal evidence as it relates to these products.
89 SN
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6567&sort=&pagenum=1" rel="nofollow">7 |
jbach ![]() Senior Member ![]() Joined: September-24-2012 Location: Kentucky Status: Offline Points: 140 |
air filters you say? if you read the post, or any of the data, you surely would've noticed the pictures, which are pretty much a dead giveaways for oil filters. I'll give you a pass, I've had a few myself this evening. |
davidg ![]() Grand Poobah ![]() ![]() Joined: January-07-2008 Location: NW Chicagoland Status: Offline Points: 2239 |
Great information Steve! Thanks for going the extra mile to find it, post it, and further explain it. Its nice to see solid data.
For what its worth, I have had a couple of parts guys and oil change guys tell me Wix is a great filter. It seemed to score pretty high on all the charts. I might have to take a look at using them if they are easy to find. |
So what this tells me there is a VERY distinct difference between the good filters (those that essentially score a B+ or higher, sticking with the letter grade analogy), and what I would call the average filters (those that essentially score between a C- and C+). This is mostly impacted by the results on the filtering ability and build quality. Which makes sense - the filtering importance is pretty obvious and as Mark (mrinboard) pointed out, filter failure is usually due to poor build quality (filter pulling away from the frame) or poor materials (filter element ripping).
So the Xtended Guard is indeed a non-orange Fram Filter (its the gold one). The Orange ones are the High Mileage, Racing and Extra Guard filters. Removing the Price from the equation, the Fram Xtended Guard is 2nd on the list and then the next Fram Filter (Racing) comes in at 9th place. It appears the most significant factors impacting their ranking are Build Quality, media surface and media volume. The next FRAM filter, 16th on list, drops off significantly from the other two. I believe the most common Fram filter (made available at most farm stores) is the FRAM Extraguard, which is way down the list. So the other interesting thing that others have pointed out, is that it would not be unusual for a company to specify a filter design that is very high quality, as consumers buy this filter and market share shifts, demand goes up, management looks to improve profits, so the manufacture specifies cost "improvements" which degrade product quality. So filter analysis identifies this degredation in quality, demand shift and the manufacture then redesigns the product to improve quality bringing consumers back. This is pretty typical of ANY product lifecycle. It would also explain why you see different manufacturers redesign filters and why you see movement of filters up and down the analysis scale over time. |
Ok, so in looking closer at the data, in an attempt to provide some more analysis for DaveG (more on that in a moment Dave), I realized that when I removed the pricing and re-ranked the filters, I only averaged the scores. To be true to the original analysis, I should actually use the weighted analysis as was done in the original evaluation, so you can see the true impact that price has on the ranking. I re-worked that information to come up with the following new ranking based on the weighted average as originally defined by author of this study:
cphase ![]() Gold Member ![]() ![]() Joined: May-11-2010 Location: Newnan, GA Status: Offline Points: 795 |
Would this not be a gas filter?
I was never one to buy into the whole Fram bashing thing. I think its all a personal preference. I use both Fram and Motorcraft with no issues.
Question: Fram did both bad and good in the tests. Which Fram filter is the good old beloved "Orange Dome of Death" (as I have seen it referenced on internet blogs). I assume the orange one is the one that scored lower?? Also, judging from the picture above, I didn't know Fram filters had such nice rounded bottoms on them. I do like that grippy stuff they put on them. It would be nice if Motorcraft did that. |
Guests ![]() Guest ![]() |
To:Mr.Peter..Kiss it baby!
mrinboard ![]() Senior Member ![]() ![]() Joined: November-23-2010 Location: Columbia City Status: Offline Points: 165 |
Oil filter tests are misleading the problem with frame filters is that when the elements get dirty the collapse or rip and the dirty oil bypass's the element. I have seen this first hand.
Dont Hate "ACCELERATE!"
WOW----------- great work SKUTsch, fantastic...
Fram is not so bad after all.I think the cat food that Mr. Peter,s wife has been feeding him ,has taken a heavy toll on his mind..He was and has been under the impression the tuna sandwiches she makes him for work and the noodle dish he loves so much was real tuna out of a can for humans. He found a can ,for feline,s in his trash one day and was wondering... See ,Mr Peter the test results do not lie! Fram is making a come back, while you are being feed cat food for LUNCH! |
Page 12> |
