  New Posts New Posts RSS Feed - Packing Nut Tightness? V-Drive 2001?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Packing Nut Tightness? V-Drive 2001?
    Posted: June-08-2013 at 2:20pm
Ben,
Hand tighten the gland nut first. Check it for drips as well as how hot it gets. You need some dripping since the packing is water lubricated but you don't want it to run hot ether.
bsnively View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsnively Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2013 at 12:02pm
I was in the process of repacking the shaft seal, and didn't know how tight to put on the packing nut.
When I took it off -- I was able to do everything by hand (loosen the packing nut/etc)...but figured that was likely too loose.
Is there a standard method of making sure it's tight enough. For example, do it by hand and then using the tool X number of rotations/etc?
Thanks,
Ben
