  New Posts New Posts RSS Feed - Barefoot Internation Boom Bracket
joespond View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joespond Quote  Post ReplyReply Direct Link To This Post Topic: Barefoot Internation Boom Bracket
    Posted: July-01-2013 at 11:11am
Sounds good. I will give it a try!
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2013 at 10:52am
Nope. It is thick enough that the bracket snugs down on it plenty tight. Mine hasn't budged in years, even with my 195 pounds dangling off the other end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joespond Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2013 at 10:33am
Thanks,
Has it ever tried to move on you, as in trying to move up the pylon from someone hanging on the boom and stuff?
SN206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2013 at 12:54am
That would likely save you from marring your pylon too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2013 at 5:41pm
I might be able to save you a little time and money. I was in a similar situation when I bought a used boom that came with a 3-inch bracket. Solved the problem with a Fernco fitting from the hardware store. I slit a section out of it so it would fit. Works like a champ.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joespond Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2013 at 1:25pm
I need a mount for a 2 1/2" BI Boom. Old boat was a 3".
Thanks.
