1996 Super Sport latch wiring |
flipflop
Senior Member Joined: June-15-2010 Location: usa Status: Offline Points: 187 |
Posted: July-22-2013 at 3:44pm |
Take a few pictures while you're in there for reference. I believe there is a ground coming from dash and 12v+ linked somewhere after the ignition breaker.
rogier
Groupie Joined: September-01-2008 Location: Netherlands Status: Offline Points: 77 |
Ok I'm going to troubleshoot wire by wire in the dash.. Hope I find it!
rogier
Thanks, these posts answer mainly the wiring question at the back where the actuator is. This is not so hard, got that fixed already. If I connect a + and - to the switch it will work like a charm.
What I'm looking for is where the original wires come from the dash wiring (color coding) to the switch. This is where I want to connect it to, since it is the last piece of electronics that is not back as it is supposed to be. Anyone? |
flipflop
Are you trying to rewire the hydraulic engine hatch? (ie. the toggle switch near the throttle?) If so, it's just a set of two bosch style relays run between the battery and ground with the toggle switch controlling the relay.
Maybe something like this? |
rogier
Maybe it's out there somewhere on the site, but I gave up after 60 mins of searching. Anybody have the color coding for the 1996 super sport nautique hatch? I've got everything rewired and this is the one that is not going perfect yet.
