Trying to isolate whats burning ignitor/coil |
Post Reply | Page 12> |
Author | ||
DrStevens
Senior Member Joined: October-15-2011 Location: Columbus, OH Status: Offline Points: 422 |
Posted: August-29-2013 at 7:30am |
I agree with Pete, per his advice in past posts, I removed my EI and went back to points. Everything has been working great since!
Go back to a point set. A EI conversion IS NOT a upgrade!!
Plan B
Groupie Joined: April-23-2013 Location: Clearwater, FL Status: Offline Points: 48 |
Update:
Pertronix II ignitor system lasted longer that the Ignitor I unit but ended up leaving me stranded only after a few months of use. Maybe it would have lasted longer with a ballast resistor but Pertronix instructions are to not use one. I have since purchased and installed a Mallory Marine Unilite Distributor PN# YLU554DV and have been running strong since, fingers crossed for the long run. "I" would steer clear of Pertronix electric upgrade to anyone thinking about going down this road, on this application at least. I spent an ample amount of time on here, with Pertronix customer service, checking and rechecking everything with voltage meter and such, not to mention wasted lots of money! Save yourself the time, hassle, and money. |
SNobsessed
Yes on Autolite 24 @.035.
Coil should not be hotter than the exhaust manifolds. If it is, you need a ballast resistor (look under the breaker cover at rear of the engine, you may already have one that was disconnected). I think you can put some dielectric grease in the wire boot to prevent arcing, you may want to try that before replacing the wires. |
merbesfield
Senior Member Joined: June-22-2009 Location: Lake Rabun Status: Offline Points: 183 |
I would like to jump in here. I have had my boat, an 84 SN2001 for three years and other than changing oil and plugs once it has run flawlessly until just recently. It does have a Pertronix setup and the coil says it does not require external resister. My boat started skipping a touch upon idling back to the dock. An earlier post led me to believe that maybe the coil had gone bad. I swapped it w a new one and it runs exactly the same, so not the coil. While looking at the motor while it was idling, I noticed sparks jumping down one of the plugs from the boot to the base of the plug. So I figure I need wires. I will do plugs at the same time. When I ran the boat last week after changing the coil, it, the coil was extremely hot. Plan is to change plugs, wires, dizzy cap and rotor. Anything else? If system is performing well, how hot should a coil be? Too hot to touch? Warm? Burning hot? And last question, Autolite #24 plugs gapped at .035 as mentioned above, correct? Thanks for all the help, Mark
65 'cuda
+1 YES, YES, YES. Good find on those instructions. Fix your plug gap then follow the steps! |
Plan B
Thanks for the info, going to drop the gap now. |
wwchevy
Senior Member Joined: August-22-2011 Location: Michigan Status: Offline Points: 369 |
"Using a coil with too little primary resistance can cause the ignition module to overheat and misfire until it cools down again or fail, voiding the warranty." I actually have the Hot Spark EI conversion on my last 3 boats with no problems. HW is correct about the instructions. Start at the top and go step by step with the digiatl multi-meter. That will tell you weather you need a ballast resistor in the system or not. Someone had put an Accel coil on my current boat and I switched back to the stock coil because the Primary resistance was too low on the aftermarket coil- about 1.0ohms instead of the minimum of 1.5ohms. I run the ballast resistor because my coil states that it requires an external resistor and when I checked the voltage as stated it was within spec with the external resistor in place. Go back to the basics and good luck. |
wwchevy
1989 Barefoot Nautique |
SNobsessed
Spark plug gap should be .035 inch. Maybe that is the problem.
Plan B
I changed the plugs, plug wires, and distributor cap. From talking to others old plug wires could be/been the cause. Previous cap and plugs all seemed fine but changed them anyway.
I used autolite 24's gap .50ish not sure of the old plug gap. That is a great write up, saved right to my favorites! |
Hollywood
And all you did was change the plugs? What was the old gap and what's the new?
I've also heard, but not confirmed (tuber), that an incorrect rotor-plate gap can overheat a coil. This seems to be the most logical instruction sheet for an EI conversion I've seen. |
Plan B
Spark plug wires were pretty old, maybe they were causing the coil to over-heat.
After replacing spark plug wires, plugs, and new distributor cap all seems well so far. I ran her for about and hour out in the open water then ran her at idle for about two hours at the dock without the coil over heating. Yesterday, it had over heated by now. I bought but did not install resistor, wanted to do things one at a time in order to know what's causing/caused the problem or it would bother me not knowing. Thanks you guys for your input, will update if it fails again, otherwise I'm a happy skier! |
Plan B
Ballast resistor is one of my hail mary's, I will throw the pertronix crap away if I can't figure out how to fix what I got first.
Hollywood
Well I hope you believe in miracles.
Throw away the Pertonix crap or put a ballast resistor or wire in before feeding the + side of the coil. |
Plan B
Sorry to hear that Seals, it's extremely frustrating to say the least. It seems to have everyone stumped that I have talked to. I have been eyeing the DUI distributors but fear that this problem will carry over into that as well. With the money I have dumped so far I could have easily afforded one that's for sure. Seals please respond back with your results, I'm curious to see how it turns out. I hope my last few hail mary's pay-off tomorrow.
Seals
Newbie Joined: May-17-2010 Location: Indiana Status: Offline Points: 17 |
I've been having the same issue with my 79 commander which has a petronix ei upgrade in the points type dist. It's wired correct and I've tried with & w/o ballast resistor as well as internal and external coils. Just pulled distributor and having it rebuilt with points installed. After being stranded many times and spending a small fortune on coils, I plan to keep spare points and condenser on board for a quick change if ever needed.
Plan B
Not much of an update (got rained out) but, after I got back from buying new cap, plugs, and wires, she started right up. Happy to see that the pertronix is atleast going into protection mode like it claims. Now hoping that tune-up will be the fix for the coil overheating. Seem so close yet so far away...I just want to go skiing...
65 'cuda
I don't know, if Pertronix says you don't need the resistor...the arithmeticsays you are putting aa lot of amps through that circuit. The evidence says your coil was really hot and now you have no spark. Your local auto parts store should have a ceramic ballast resistor in stock. You won't hurt anything by adding the resistor, what you are doing now is not working.
Plan B
Hollywood,
I do not see any mention of resistance..only a resistor which is to remove it if there is one, I do not have one. Going to purchase new plug wire, plugs, and cap, just in case something is causing a spike. |
Plan B
Petronix guy says I do not need a resistor...
He had me run a test, run a ground wire from block to negative on coil. He wanted voltage at coil while engine turning and with on position. with on position I was reading 11.5v While turning I was reading 9.2v Gary, I trust your judgement and at this point would be more than happy to give your recommendation a shot. Is this something I can pick up locally, if so what specifically am I looking for? Seems like another new coil may be on the list also. |
65 'cuda
I think you will need a ballst resistor you want to limit the current(heat) in that ignition circuit to 8 to 10 amps. You are 22-24 amps. Get a resistor in that circuit. You need another .75 to 1.00 additional ohms of resistance.
Hollywood
What do the installation instructions say about circuit resistance?
Plan B
Phew...I got back to the dock...
So, took the boat out for a spin, ran great for about an hour, then stalled. After turning everything off and letting everything cool, including my self, luckily she started back up. Coil was hot to touch way beyond warm. Gary, just went out to check, with it running it's at 14+ with key in the on position it was at 12.4 I went to restart it to double check, no spark...hopefully protection mode is doing its job. Calling pertronix now. |
65 'cuda
With the key on, set your volt meter to DC volts in the 20 volt range and touch the positive lead to the positive side of the coil, and the negative lead to the engine block, what is the voltage?
65 'cuda
With a .6 ohm primary resistance in the coil, you may need a ballast resistor, Check with pertronix. Run the boat then feel the coil, it should be warm but not hot.
You have the same danger of burning up the coil with the points system if you leave the key on and the points happen to be closed. I think the ignitor II has some protection built into it. |
Plan B
Ok, re-wired all my accessories to run independently straight from the battery (fuse box) vs. there original position from the ignition switch.
FYI, I initially daisy chained accessories to ignition thinking this would prevent unwanted battery drainage...lesson learned. Installed new pertronix II ignitor and coil (0.6 ohm). Not super savvy with multimeter so I'll explain in detail what I did and what I got. With no key in ignition.. Primary test - Set to Ohms, (-) lead to (-) post on coil, (+) lead to (+) post on coil, meter was jumping from 000.4 to 000.6 Secondary test - Set to Ohms, (-) lead to center of coil, (+) lead to (+) of coil, meter read 9 I'm hoping this is the fix to what was causing my coil/ignitor to burn up. If it is great, although, I still find it bothersome knowing that if the key is accidentally left in the "on" position how easily it is to burn up the system. There must be a way to eliminate this. The pertronix II does state, "Senses startup and develops more energy for quicker, easier starting. Built in reverse polarity and over current protection shuts down the system, preventing component damage." I hope this will also help in my situation vs. the pertronix I system which did not do this. Boat starts and runs beautifully! Hopefully for more than 3 hours this time!!! |
Hollywood
You can always go directly to the battery as well.
Plan B
I just replaced the ignitions switch, if I would have known this prior, I would have opted for one with an ACC option.
My nav light switch has been re-wired to the 6-gang rocker switch board Thanks for the knowledge fella's, hoping to receive new ignitor/coil within the next few hours...of course the water is like glass... |
Hollywood
Or wire the stereo to your nav light switch
backfoot100
You could always replace the ignition switch with one that has an ACC position and wire the radio to that (just like your car). Just put it on ACC when the engine isn't running and you want to listen to the stereo.
Eddie |
