  New Posts New Posts RSS Feed - hdr600
hdr600
floppy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote floppy Quote  Post ReplyReply Direct Link To This Post Topic: hdr600
    Posted: February-22-2006 at 4:53pm
thanks worked like a charm.
AWhite70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AWhite70 Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2006 at 9:28am
Like '79 said...
The procedure is a little different depending on the model of boat you have but is generally the same. I've installed depth finders on both my '79 and my '02.
I look for where the wires go from the engine compartment up through to the dash. On the '79 there is a tube they pass through, I can't remember if there is a tube on the '02 or not.
Anyway, I started in the engine compartment with a length of household 14/2 electrical wire (romex). I used this because I had it readily available. Anything that is somewhat stiff but still flexible will work (you can't push a rope). Start feeding the wire through from the engine compartment to behind the dash. Once it comes out the other side tape the transducer wire to it and pull it through.
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2006 at 8:24pm
79: Where are posting from? Up home or St. Pete? Sorry we couldn't hook up.
john
"Loud pipes save lives"
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2006 at 6:12pm
follow all the other wires from behind the instrument pannel
Post Options Post Options   Thanks (0) Thanks(0)   Quote floppy Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2006 at 4:51pm
any hints on how to run your transducer cable through to bilge area. thanks
