  New Posts New Posts RSS Feed - Ignition points mounting plate & dist cam
Seals View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seals Quote  Post ReplyReply Direct Link To This Post Topic: Ignition points mounting plate & dist cam
    Posted: July-16-2013 at 11:41am
Trbenj- it is a clip down presto lite. I have picks but can't seem to paste them into this post.
Tag # D3JL- 12100 B.   8L.
IBM 7008AS11L.   Thanks for your help. I'll send a pic later
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2013 at 3:02pm
Originally posted by Seals Seals wrote:
1979 sn commander, 351C engine
Trying to convert ei ignition back to the original points based system
Need mounting plate for points, points, condenser, and distributor cam
Unless you have a very rare/oddball engine, I would imagine you mean 351w.
It would help if you told us what type of distributor you have, as things differed between marinizers and quite possibly swapped out by previous owners, etc. Im guessing a clip down Prestolite, but a picture would confirm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seals Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2013 at 3:00pm
