1978 ski nautique points dizzy and carb for 351W |
Posted: July-31-2013 at 3:34pm |
2 batteries in 23 years is not bad,if I buy an optima it might be the last one I need
Hollywood
Maybe you should stop using your old car batteries!
And it was the seasoned veterans who had issues at GL
Hollywood
I would stick with a marine carb if I were you. A seasoned veteran could get by but they'd probably keep a closer eye and have the knowledge on what exactly to be checking up on.
ny_nautique
Platinum Member Joined: June-01-2011 Location: Albany NY Status: Offline Points: 1215 |
All of the 351s in these boats are Windsors, not Clevelands.
- Jeff
1999 Ski Nautique |
CrazyCanuck
Senior Member Joined: July-21-2013 Location: Vancouver B.C. Status: Offline Points: 254 |
Thanks. Hollywood is sending me a dizzy....so I may be scratching that off my list.
Can an auto carb be safely modified for marine use? I can get a marine carb for 260 bucks, but ouch....that's a lot. The carb I have a price on is the cm 702 from autolite. Anyone here use that? The Holly 4160 is hundreds more.... Thanks Corey. |
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
kblv247
Newbie Joined: July-22-2013 Location: washougal Wa Status: Offline Points: 39 |
is it a 351w? 351c?
62 wood
New dizzy on ebay... says its from a SN ..
Dizzy also... I might have a used one ...can check and see for you. |
CrazyCanuck
Hi all.
I need a couple things for my new project. I have the 351 but have an auto carb and horrible duraspark ignition. I want to go back to a marine points dizzy that if needed I can upgrade with a kit. I also need a marine carb for that same engine. So far my best new price is 260 bucks..... |
