  New Posts New Posts RSS Feed - Boat sunk but had factory foam
74Wind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Topic: Boat sunk but had factory foam
    Posted: August-01-2013 at 8:53pm
Originally posted by Keuka Keuka wrote:
I checked back on the link to this forum. They did get the boat raised from the bottom and in the pictures it didn't look too bad considering the circumstances. It was found upside down about 30ft from where it was marked. They are thinking it will still be a total loss considering the $9200 fee to raise it.
David
$9200,Yikes. Time to confirm "Wreckage Removal" is clearly stated/included in our insurance policies, eh? And fuel spill liability.......
1974 Southwind 18
1975 Century Mark II
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2013 at 11:10am
A guy from my home town had an early 90's Supra of some sort. They took on a roller and water and rolled it over on their vacation. They towed it back to the dock (tower and it floated). Rolled it over drained all fluids and let it air out for a day. Re installed fluid hit the key started checked all systems and went skiing that next morning. Used it just fine ever since!! I don't think they even made a claim (guy is an insurance adjuster).
Art, I am pretty sure there is some beer down in the foam from my college days!!
Keuka View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keuka Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2013 at 11:04am
David
86 Martinique
ArtCozier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2013 at 7:15pm
It's not quite as soft as the foam on your beer!
Art
"Art"
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2013 at 4:57pm
The foam under my floor makes it have a nice soft springy feel so it's not as hard on your feet walking around the boat.........
Oh wait it's not supposed to be soft?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2013 at 4:56pm
There is foam under both of your floors still
mdvalant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdvalant Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2013 at 4:44pm
Now that I think about it, there's no foam in our Sporty...that I've seen.
I guess the floor would have some? Dad's 90 Ski had it under the gunnels and the underside of the bow deck was full of foam.
'90 Ski (sold)
'00 Sport
Mississippi River - Bellevue, IA
89Martinique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 89Martinique Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2013 at 4:32pm
So my 20'2" CC doesn't have foam? That would be nice to not have to worry about. My Supra is fully composite so no rotten stringers to ever worry about.
Current Boats:
1992 Supra Comp-TS6M PCM 351w HO Pro Boss Pro-Tec Ignition - Full Composite (no wood stingers!)
1989 (3rd Gen) Correct Craft Martinique B/R PCM 351w Power Plus
1984 E-Scow
Keuka Lake,
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2013 at 9:52am
It doesn't specifically say foam - an air chamber would pass. Pete, your good to go!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2013 at 6:23am
They don't mention tubes!! I wonder if I need to get my pro tubes filled with foam?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2013 at 2:35am
Interesting to note that it has to float but not in any way you or I would think it should
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2013 at 1:38am
Originally posted by 89Martinique 89Martinique wrote:
I would like to see the no foam over 19' to be backed up, interesting...
It's not,here it is-
Subpart F - Flotation Requirements for Inboards, Inboard/Outdrive, and Airboats
FEDERAL LAW
183.101 - Applicability
This subpart applies to monohull inboard boats, inboard/outdrive boats, and airboats less than 20 feet in length, except sailboats, canoes, kayaks, inflatable boats, submersibles, surface effect vessels, amphibious vessels, and raceboats.
Discussion:
Monohull inboard, inboard/outboard boats and airboats less than 20 feet in length must comply with a flotation system called Basic Flotation. Basic Flotation contains the requirements and tests. Basic flotation is the simplest type of flotation mode covered in this regulation. It simply requires that the boat be manufactured with sufficient flotation material to keep it afloat in the event of a swamping. It does not, however, require that the boat remain in an upright or indeed any specific position. It may float, and usually does, in a "spar" position, the bow sticking up and the stern sunk. The requirements include some materials tests. Basic Flotation covers this type of flotation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 89Martinique Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2013 at 1:27am
Supra's are like malibu's. If your not careful, very easy to take a wave over the front.
CCFans, I wouldn't visit Lake Sunapee if I were, even though its very pretty!
Current Boats:
1984 E-Scow
Keuka Lake,
Airfooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Airfooter Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2013 at 12:44am
Very interesting quote and comment on page 8 of that discussion....
1992 Nautique Excel
skutsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2013 at 10:01pm
Originally posted by ArtCozier ArtCozier wrote:
In my '65, all the screws were on top of the vinyl floor covering with finishing washers on them. And they were Phillips drive. And battery screwdrivers were not yet available to the general public at affordable prices!
Art
Maybe I am wrong on the screw heads, but I second the battery screwdrivers, I think I still have the scars on my palms from the floor replacement project...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2013 at 9:19pm
Originally posted by skutsch skutsch wrote:
Art when did they start foaming the Ski's. Dad's 63 did not have foam.
I'd bet around 1968 when the powers that be also decided what switch knobs to have on our dash boards and bumper heights
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2013 at 9:08pm
[QUOTE=ArtCozier]
My personal experience was that I took all of the foam out of my '65 SN when I worked on it in '67.
Art
Now that you mention it, I have a '64 that does't have foam in it now. Next time I see it, I'll have to look and see if there are signs that a PO took the foam out.
Art
"Art"
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2013 at 7:06pm
Art
Hollywood, removing the floors was easy; peel back the flooring and unscrew the screws, only problem was they were all straight blade screws if I remember correctly...
DeepCreekNauti View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DeepCreekNauti Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2013 at 6:47pm
We have a '05 206 SNOB and we have taken a few serious waves over the bow that totally soaks the entire boat. Many have run right up and over our windshield and filled the entire bilge area.
It mostly stems from coming out of gear and hitting a big wave while the boat is settling nose down and stern high. It has happened more and more over the years since every new age ski boat has the displacement of a battleship throwing a monster wake.
On Deep Creek, on a weekend, taking a wave over the bow is unavoidable since I got to get the boat back to a down skier before Mr. John Q. Idiot behind us runs them over.
Never would have thought any of these waves would have put the boat on the bottom though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DeepCreekNauti Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2013 at 6:40pm
My guess...when the guy gave it throttle to get the noise up after the first wave he invited disaster. A whole lot of water can come over the bow in seconds especially since it was bow heavy from the first wave. He simply drove more water in.
jbach View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbach Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2013 at 6:16pm
that's a malibu response. those things have very little freeboard, and have an extremely low bow. i could easily see taking a roller over the bow. maybe he had steel/lead or additional ballast in it. i've taken a couple over my 210 bow and could see how it could get interesting, real fast. even with dual pumps, it takes several minutes to get all that water out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2013 at 5:44pm
Sure did, the foam in the deep part of the bilge between the front seats was water soaked. It was open-cell foam. I had the floor out of the boat for other reasons. {remember, the floors were not glassed over until about 1969 (??)}
The boat had lived its whole life outdoors until I bought it.
Art
"Art"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2013 at 5:22pm
You took the floor out of a 2-3 year old boat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2013 at 5:07pm
I don't know how an insurance co. would react if one were to have a sinking on an old boat that had the foam removed. It would depend heavily on what date the flotation requirement was put into effect by the USCG. I know we have foamed boats since the early 1960s, but the early foam wasn't closed-cell foam so it behaved a bit like a sponge!
I think if the boat had been built after the requiremenmt went into effect, the insurance company would have an easy out on a claim. If someone drowned as a result, I think it would be a BIG problem.
My personal experience was that I took all of the foam out of my '65 SN when I worked on it in '67. One afternoon a friend called and needed to use my trailer, so we launched my boat and moored it out in the lake. That night just after I settled in bed for the night, I remembered the drain plug was still in the pocket on the back of the driver's seat. Of course the boat was on the bottom of the lake. I got the friend who borrowed by trailer to come help (in the middle of the night) to come help, and we horsed the boat into shallow enough water to get the gunwales above water, then I bailed it out with a bucket. Took off all the electrical stuff and put it in the oven at low temp with the oven door open. Changed all the fluids and went skiing with it the next afternoon.
If I rebuilt an older model boat today, I still wouldn't put foam back in it. But I might check the effective date of the flotation law.
Art
"Art"
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2013 at 4:21pm
Bret, That's where I am going with it ;). I am just curious if a boat sinking to the bottom that was supposed to float would raise any eyebrows but then again it's stuff that was assembled 30 years ago so who knows if it would still float. The wood boats get the foam filled up with water like ballast soooooo..
Mine will probably go back together sans foam.
panda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote panda Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2013 at 4:17pm
Even though he said that the boat had no ballast in it, I am going to guess that he had some steel plates in there. Steel will make the boat sink like a rock.
95 Ski Nautique GT40
bhectus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhectus Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2013 at 4:13pm
Originally posted by phatsat67 phatsat67 wrote:
Interesting Art. What's your take on what insurance companies will think of boats that sink that have been re floored without the use of flotation foam?
How would they know? It's a sealed cavity right?
'87 Barefoot - sold
'97 Super Sport Nautique - originally custom built for Walt Meloon
'97 Ski Nautique
'83 SN 2001
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2013 at 4:05pm
I have never seen a PWC make a wave big enough to spill over the sides or bow of another boat. I have two jetskis and the only way I can throw a large enough wave is to slide it or do submarine donuts.
'92 Correctcraft Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2013 at 4:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2013 at 3:54pm
Another angle to this is the status of the boat with the USCG rules. My understanding is that any boat under 20' has to have positive flotation. It doesn't have to float upright, but some portion of the boat has to be above water when it's completely flooded.
When they test our boats, we take a current hull, install a block of iron on the engine mounts that weighs the same as an engine package, and put old upholstery in the boat. They take a razor blade and cut open all the vinyl on the upholstery so that it can't hold air, and open all closed compartments so that they flood. Then they pump water into the boat and leave it sunk for a given number of hours. If it goes under, you don't get your approval to build and certify it.
Art
"Art"
