  New Posts New Posts RSS Feed - Tranny Fluid
Tranny Fluid
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Topic: Tranny Fluid
    Posted: August-23-2013 at 10:07am
BeeJay, go to O'reilly auto parts and pick up a suction gun. It has a flexible clear tube and you can pull all the fluid out with 10 pumps or so. Easy and clean and the gun costs about 10 bucks.
BeeJay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BeeJay Quote  Post ReplyReply Direct Link To This Post Posted: August-23-2013 at 12:54am
Okay. I'm off to buy some 1/8' copper tubing.Thanx.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2013 at 8:24am
BJ. Yes, the copper tube will go to bottom. It needs to be straight. There is a small pilot hole that is 1/2 way down that you need to go thru also. You will not get all of the fluid out, but it doesn't matter - unless you are changing from motor oil to ATF, or your ATF has water in it. (in those cases, you have to change it several times).
Post Options Post Options   Thanks (0) Thanks(0)   Quote BeeJay Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2013 at 2:24am
Will the copper tube actually slip all the way to the bottom without hitting any obstruction? My first attempt was with a Jabsco drill pump and the pickup hose that came with it (1/4 " plastic) that hose could not penetrate more than 1 or 2 inches.Also if successful pumping out the sump,would there be much oil left in all the passages and such?
Post Options Post Options   Thanks (1) Thanks(1)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2013 at 9:26am
BJ - use a 1/8 inch copper tube (icemaker line) to get down into the sump. It is best to have it long enough so the hose connection is above the fill port (Others have dropped a short tube into the sump & had to disaasemble). You should be able to pull out just shy of 2 qts.
boardersdad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boardersdad Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2013 at 4:12am
Welcome!
Check out this thread: Transmission Fluid Type
Also, try the Search function at upper right.
Although it doesn't always work so great, so use Google with:
site:correctcraftfan.com transmission fluid
or whatever you're searching for.
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote BeeJay Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2013 at 1:53am
Hello All
I have a '97 Cmpetition Nautique with a 351 Ford PCM engine and PCM transmission. Altho the tranny oil looks and smells good, I figure its about time to change oil in it. The wortless factory manual that came with it tells me nothing. I see no evident drain port, so attemted to pump it out of the fill hole. An ounce or two was the best I could do and then nothing. What is the method used to drain that oil?
