  New Posts New Posts RSS Feed - 73 marauder packing
73 marauder packing
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Topic: 73 marauder packing
    Posted: August-31-2013 at 1:48pm
Good question Pete.
The White Teflon is good for over 7600 rpms
The GFO is more than double
The White Teflon will withstand slightly higher pressure.
keith1377 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote keith1377 Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2013 at 9:48pm
Thank you for your help. I have an open bow bayliner capri with an outboard, so this boat is a whole new animal that I am taking on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2013 at 8:02pm
Originally posted by DrCC DrCC wrote:
Quarter inch 4 the Rudder and Three sixteenths 4 the Prop Shaft.
20 feet ???   OMG !!!
Pete, That's enough packing for you to become the new "Marty"
My personal fav is the White Teflon.
Al,
I can buy 20' of GFO from Mcmaster for the same price Skidim rips off people for a couple feet!! Yes, it will last me for a few more boat restorations and existing boat maintenance's!!
Details on the Teflon packing your use? What is the FPM max?
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2013 at 7:43pm
20 feet ???   OMG !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2013 at 7:12pm
It's ether 3/16" or 1/4". CC used both. Remove the packing nut and measure. I as well as many other members have been having very good results with the GFO packing. I buy it in 20' lengths from McMaster but they do have smaller quantities. Skidim also has it but at 10 times the cost!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote keith1377 Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2013 at 2:04pm
What type of packing do I need to order for the prop shaft inside the log, also the rudder shaft. Also what size would be helpful. Thanks
