Transducer wire pulled out :/ |
shagit
Senior Member Joined: March-14-2008 Location: United States Status: Offline Points: 301 |
Posted: September-02-2013 at 12:20am |
Thanks for the replies.... That's what I figured... :/
Now to find one of the pucks.... Puck'n a |
rapok4
Senior Member Joined: August-09-2013 Location: Jacksonville, F Status: Offline Points: 118 |
I have had this happen to me on a different boat and the puck had to be replaced. The hardest part was trying to re-run the wiring with a plug. I tied a string on the broken plug and pulled it out the "hard" way to see if I had to cut wire ties or move anything else in the way. I have been told the composite can be removed, wires soldered, then epoxied, but the manufacturer was against it. I replaced mine.
backfoot100
My guess is that you're SOL. Every one I've seen is hardwired into the puck and then sealed. You'll have to get a new puck and replace it. I know that they sell them separately.
Eddie |
shagit
The transducer wire has been pulled out of the puck, on this teleflex transducer that I have. Anyone know if they can me re- 'stuck' in and still work?
Thanks! |
