temperature of my 92 sn |
Smithfamily
Platinum Member Joined: December-26-2007 Location: Orlando, Fl Status: Offline Points: 1602 |
Posted: September-17-2013 at 8:37pm |
That's where I am at. 1992 SN 351 |
Js
kapla
poor grounds are normal in the dash, I suffer from hot reading when I turn the nav lights, gauge normal range reads 160, once I hit the light bam it moves to 200...
I have to addres this problem asap... so to your answer normal t is 160, it will rise some if you turn off the engine and restart a few minutes after... Correct T stat for the carbed engine is the 143º...check impeller and make sure all the hose are tight to prevent them from sucking air... |
<a href="">1992 ski nautique
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13515 |
Yikes 220 is hot, not good. An impeller inspection would be first. It's going to take several hours to air cool, the gauge is fine besides a loose connection would read low.
nautique92
Newbie Joined: September-02-2013 Location: cary,il Status: Offline Points: 11 |
Thanks, so another Q the other weekend my temp. Gauge was pegged all the way past 220 let the boat sit awhile and temp didnt go down and the.gauge didnt return to the right when turn off either but now seems ok like at 180, could there be a lose connection somewhere that is giving me the false reading?
levinmark
Senior Member Joined: November-11-2010 Location: illinois Status: Offline Points: 375 |
Your normal operating temp should be at 160, and I believe a 140 thermo will get you there. Others will chime in soon
levin
nautique92
So my 92 sn has a 351 ford and it is running around 180/190° i think its a little on the high side what is the.proper temperature range,im going to change my impeller to see if that make a diferance if not what temp. thermostat do i need.
