Help with tune up ! |
tcarden
Groupie Joined: February-21-2006 Location: United States Status: Offline Points: 54 |
Posted: March-24-2006 at 10:02am |
Congratulations Dan! I just bought an 82 Sn also. Go online to www.skidim.com. They have everything you'll need and great advice and service too. I ordered a new strainer for mine, It didn't have one either, for $39 bucks. Good insurance I think.
JEFF KOSTIS
When I change the trans oil, I take 5 minutes and seperate the shaft from the trans (4 bolts) which allows me to run the boat "in gear" to help mix things up before I dump the oil. I cant say how much actual benefit there is to this, but it seems to get the gray clutch material out better.
Jeff... |
M3Fan
The tranny screen is just inside the inlet of the transmission cooler.
79nautique
autolite 24 for the plugs, you may or maynot have a strainer, if not then get one and install it yourself. If you do it will be inline with the pickup hose and before the tranny cooler.
dans
Senior Member Joined: March-23-2006 Location: United States Status: Offline Points: 187 |
Just got a 1982 sn 2001 w/ ford 351 and velvet drive tranny. My manual is newer (1989) - What kind of autolite plugs go in a 1982(14 or 18mm ?) Do I have a water stainer sceen & a tranny screen to clean ? Can't find it.( maybe not on the 1982). If someone knows exact part # or name for autolite or motocraft plugs that would be great , then I can go to autostore here . Thank You !! P.s I think I have the 240 hp 351. Dan
