Boat floor material |
Morfoot
Posted: February-13-2014 at 1:22pm |
He was.... we talked since his post and I said....OOOP never mind...I was thinking pressure treated...Scratch that! .It musta been a the sleet/ice we just got...you know....Brain freeze.... Mike, the pics make the verbal discussion we had about this worse...You've got a small mess on your hands but know you can handle it. Love the replacement foam job. I wonder how hard it took the shade tree mechanic to get to "Foam Wormies" to come out like that... Talk about a half @$$ job..... |
Nautiquehunter
Platinum Member Joined: December-31-2008 Location: Lake Lanier GA Status: Offline Points: 1010 |
Hey Zach I am 35 miles north of Atlanta on Lake Lanier If you need a place to stay you are more than welcome.
Jim I have gotten a lot of work done but I am almost out of materials and nothing is running or open. |
jimsport93
Platinum Member Joined: February-20-2008 Location: Alpharetta Ga Status: Offline Points: 1750 |
Mike, this crazy weather ought to give you plenty of time to work on that boat. Nothing else to do....well, almost nothing else
Hope you and Gail are doing well. Look forward to seeing you again soon. |
Waterdog
Marine ply bonds well, It's the floor in most toons & the carpet
is glued to it. 3/4 Marine / Tropical grade is also 7 plys Pressure treated on the other hand is much heavier, glue / resin doesn't like it and has no place in a boat. |
phatsat67
Looking good so far Mike. I will hopefully be going down that road in a few months.
Nautiquehunter
Thanks guys
The boat is a 84 Supra Comp I picked up last year for 2500. It had stringers put in a few years ago. I started with removing the engine for oil leaks and new carpet once the carpet was up I saw how bad the deck was laid and now the top cap is off, foam is out and I'm looking at a some what poor stringer job. At this point I think I will sister to the secondary's and rebuild the structure at the sides the mains although sloppily done look solid and the mounts line up fine. The sides of the floor were held up by stacking 1x4s and foaming them in. Here is a couple pics. This is where I am going with it. |
Michael,
I feel the other member you talked to is mistaken. He may be confusing regular plywood with treated. Both polyester and epoxy (better) stick to regular plywood. A CPES treatment is even better. FYI, marine ply and exterior use the same bonding. The difference with marine is the tight control of voids on the inner ply's since it's typically used for structural applications. Check out US Composites for the materials. |
JPASS
'92 Correctcraft Ski Nautique
Nautiquehunter
I am replacing the deck and stringers. I was going to use marine plywood for the deck. I was talking to another member and he told me the fiber glass will not adhere to marine plywood. Any recommendations? Also a good location to buy the fiberglass and bonding supply's.
