While am at it .. |
Author | ||
gun-driver
Posted: April-11-2014 at 1:03am |
Can't find just a block, salvage yards around me want to sell the whole motor. I agree with glasseeker if you didnt sign for it/accept delivery(which I hope you didn't) it should be on the carrier. |
Why not get one out of a truck Paul,I think they were used until '96 |
GlassSeeker
Grand Poobah Joined: November-26-2008 Location: Elk Grove, CA. Status: Offline Points: 2421 |
so this happened after you /someone signed for it??? if it happened during shipment thats on the carrier.
This is the life
malibud
Gold Member Joined: July-08-2009 Location: north carolina Status: Offline Points: 613 |
Update. So a couple blocks from my pick up spot the truck driver had to lock up the brakes for someone who decided they needed to take a left hand turn. Engine shifted crate broke. engine is lying on oil pan smashed with oil leaking out..... So filed insurance with a 500 deductible. Carrier already said its not their fault ...I think i maybe ok since I paid extra.
Might need new thread but Can I use an Automotive oil Pan ? Can I use automotive Pick up ? Thanks Dan |
gun-driver
Dam I'm looking for a '94 or newer block. |
storm34
Since you're pulling everything you might as well pull the prop off and install a new strut bearing. Easier to pull the prop than the coupler from what I hear.
Dreaming
check your steering cable, change cooling hoses, impeller, trans oil etc. I'd just do the regular maintenance stuff, more because it's a new boat to you, and you don't know what has been done in the past. once you've done the routine maintenance, do a good shakedown cruise and pay attention to all the little details. you'll probably find more to change.
malibud
It has a cracked block I am pretty sure got down close to 0 . all freeze plugs popped out and the oil is milkshake. Going to mothball it till I can make sure all is good with new, used engine
gun-driver
What are you doing with the old motor is it junk? It's a GT -40 I presume
malibud
Pulling the engine from 97' sport and replacing with a excalibur. Anything else I should do boat has 625 hours. Check damper plate. clean bilge any other ideas ?? Install paddle wheel for PP
thanks |
