  New Posts New Posts RSS Feed - Need Source for Replacing Gas Springs
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Topic: Need Source for Replacing Gas Springs
    Posted: June-23-2014 at 5:22pm
NautiqueParts.com
Glove Box S3193
Hatch and Engine Cover S3733
I bought all 5 shocks for $103. recently with freight.
95 Ski Nautique They were stiff when new but are working fine.
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2014 at 3:45pm
I got mine at NAPA. Same thing used on hatchbacks. You need to make sure you get the length adjusted the same so both are pushing out the same amount when the seat is at the highest point.
Tim D
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2014 at 12:32pm
I'm sure Zach at N3 Boatworks can hook you up. Nautiquepart.com will have them too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2014 at 12:32pm
mousecreek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mousecreek Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2014 at 12:26pm
The front passenger seat of our 94 SN needs new gas springs. The old ones are useless, and the wood pole I have been using is just inconvenient. Some other gas springs in the boat need replacing as well. The original pair was made by Spring Lift Corp (SL3-55) but it seems they only list automotive applications. Stabilus is another brand, but I need help matching the specs to the old pair.
What sources do CCF members use/recommend for finding the right replacement gas springs?
