  New Posts New Posts RSS Feed - Perfect Pass
Perfect Pass
AAM196 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AAM196 Quote  Post ReplyReply Direct Link To This Post Topic: Perfect Pass
    Posted: July-21-2014 at 4:27pm
Yeah, I use the RPM for slalom... just trying to get the speed accurate as well for kicks. I'd go GPS route if I didn't boat on rivers.
My paddle is right where it says to install beside drain plug.
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2014 at 1:36am
A second thought, switch to RPM mode at those speeds which should turn the paddle wheel off. I know PP prefers RPM's for slalom so they should be good for higher speeds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2014 at 1:29am
Upgrade to Stargazer and you won't have to change it out.   If it it looses accuracy above a certain speed I would guess there is some turbulence it's picking up so you might want to change the location . Probably easiest to leve the current one in place and add another than it would be to drill a new hole and move the current paddle wheel and fix the old hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AAM196 Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2014 at 6:14pm
Anyone ever replace paddle wheel in Perfect Pass? Mine seems to loose accuracy at times esp around 40mph. Would a new Paddle wheel help?
