Suprise starting..Help |
Posted: August-09-2014 at 8:15pm |
Did you check the commutator for shorts winding to winding. If you take it to "auto electric" shop, they will turn it down and undercut the mica.
rdana
Newbie Joined: November-04-2009 Location: wichita ks Status: Offline Points: 17 |
I ordered a marine solenoid and starter switch,it will be here Monday.I removed the starter and cleaned some rust off of the magnetic plates and the armiture.The brushes looked fine.after putting it back together,when I apply power to the positive terminal and ground the case to the ground on the battery all I get is sparks,and the starter does not turn.
CrazyCanuck
Senior Member Joined: July-21-2013 Location: Vancouver B.C. Status: Offline Points: 254 |
Could it be the ignition switch?
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
Bri892001
I saw your other thread, looks like you have a starting battery. Do you have any pics of how you have the solenoid wired?
Bri892001
Are you running a deep cycle battery by any chance?
rdana
As soon as I connect the Battery on my 83 351 ford Commander the starter turns ,what is causing this?The battery is fully charged and the solenoid is new.Any ideas.
