Ski Nautique 2001 Shift/Throttle control |
JPASS
Posted: September-01-2014 at 10:48pm |
Morse refers to the type of throttle you have in your boat. Brass barrel refers to where the cable attaches to the throttle lever side of the controls. |
'92 Correctcraft Ski Nautique
marmon77
Senior Member Joined: August-01-2010 Location: Dade City, Fl. Status: Offline Points: 112 |
DrCC, read entire post know what Morse is but not brass barrel
marmon77
Thanks DrCC but could you elaborate more? Brass barrel, Morse?
DrCC
Your pre-load spring for the throttle cable is too tight.
Adjust the brass barrel for less tension. Adjust at the Morse. Not the carb. |
marmon77
The lever seems to not center after it's put in gear then returned to neutral. If that makes sense
KRoundy
First off - what is wrong with it?
They can be repaired and are actually quite simple devices. From CCF FAQ Tell us what is wrong and then we can help steer you in the right direction. |
marmon77
Looking either to buy or have my shift/throttle control repaired. Is there someone on here that repairs them or should I look to buy one? Thanks
