Flywheel replacement |
sandbar53
Newbie Joined: December-26-2009 Status: Offline Points: 7 |
Posted: September-25-2014 at 5:39pm |
Can I remove the V-drive with the bell housing as an assembly, or should I split it? Also, to remove the transmission mount, is it ok to just unbolt the mount from the V-drive? Or should I remove the whole mount? Thanks
Rick
MustangMadness
Senior Member Joined: April-15-2014 Location: Seacoast NH Status: Offline Points: 114 |
Disconnect the prop shaft @ the coupling, the shift cable and coolant hoses to the transmission cooler, and support the engine at the rear so you can remove the Vdrive and the bell housing and then the flywheel. Heat the ring gear with a torch. It should just about fall off before you get it too hot. Heat the new ring gear enough to drop onto the fly wheel. Reverse steps and check shaft alignment.
I like a 6' beam on a small lake... My Muscleboat
1975 Mustang 225 307RH |
sandbar53
I want to disassemble as little as possible to get to the flywheel. Also, once I remove the flywheel how do you get the old ring gear off and the new one on? Thanks
Rick
hotboat
Gold Member Joined: March-28-2009 Location: Conn Lake Pa Status: Offline Points: 814 |
haha where's Don at? He's the only one I can think of that has done this but from what I know pulling the whole unit sounds best. Maybe Jodi can shed some light?
Brian
skicat
Platinum Member Joined: May-18-2006 Location: Duluth, GA Status: Offline Points: 1129 |
Sounds like a Hollywood quote to me! |
phatsat67
I would just yank it all and split it on the floor.
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3359 |
The V-drive is a little harder, i suspect the engine is what you wish to move instead.
but throw a fresh dampner on while you are at it. |
River Rat to Mole |
phatsat67
Call me if you'd like to order one sir.
Ninety8NeonACR
Newbie Joined: September-21-2011 Location: Nekoosa, WI Status: Offline Points: 18 |
I just replaced the ring gear on my 82. Just had to pull the transmission and bell housing. Only cost me $20 and a few hours of my time.
No need to replace the whole flywheel,just replace the ring gear, do a search to find out which one to use
sandbar53
I bought a '91 Nautique Excel. Starter is grinding. I removed the inspection plate and found many teeth missing off the flywheel. Not good! Someone replaced the starter and it was loose. When I tightened it, it helped the grinding but damage was done. Teeth were probably missing before they replaced the starter thinking that was going to fix it. I am going to replace the flywheel myself. Any tips? Open for suggestions.
Rick
