  New Posts New Posts RSS Feed - Rub Rail, Brackets, and Trim Oh My....
skutsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Topic: Rub Rail, Brackets, and Trim Oh My....
    Posted: May-05-2015 at 8:39pm
Hey Chris, how is all that work coming along???
ryanibanez88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryanibanez88 Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2015 at 8:17pm
Great Thanks Pete im watching your Alignment Video now
Ryan
1997 Ski Nautique
Midland Texas
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2015 at 8:15pm
Originally posted by ryanibanez88 ryanibanez88 wrote:
Any suggestion for the metal rail on my tique ]
Ryan,
The aluminum half oval is very common. rubrails.com has it if you what to replace it. It's a Teco metals profile.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryanibanez88 Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2015 at 7:13pm
Ryan
1997 Ski Nautique
Midland Texas
littleskierox View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littleskierox Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2015 at 6:30pm
If you're looking for a cheap option I would recommend just flipping the insert, especially if the casing is still solid and you heat up the rubber. We've done it before and it works really well!
My escape is to just get in a boat and disappear on the water.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littleskierox Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2015 at 6:06pm
We went through N3 Marine, it was super easy!
Frankenotter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2015 at 3:48pm
Where did you get your rub rail from?
1999 Ski Nautique 196
Post Options Post Options   Thanks (0) Thanks(0)   Quote littleskierox Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2015 at 1:37pm
We replaced the rubrail for our 176 last summer and it was a surprisingly easy process. Our boat is teal and purple and the rubrail was purple (or was supposed to be... somehow it turned into a grayish color and definitely needed to be replaced.) They don't make the purple anymore so we opted to just replace it with black.
We would have just replaced the color insert but they do not just sell it that way, it would have been convenient but... One option you could try if just taking and flipping the color insert so they the sun bleached color isn't visible.
We just got a 196 sized rubrail and cut it off, they do not sell a specific one for the 176 size, it was very easy to just cut off the excess at the end. I am pretty sure we got ours for around $300 as well so I don't think they come much cheeper.
As for the pin striping sometimes we can find it at our local auto shops, or sometimes they can order colors if you bring a swatch in, especially if you have a generic enough color, otherwise ebay is a good option.
Thanks all I got, hope it was helpful :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2015 at 6:31am
Gary in that thread you mentioned buying that stuff in red for your boat. How is it holding up? Is it fading from the UV or does it still look good a year later?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2015 at 12:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2015 at 11:28am
What about the color insert of the rub rail? Maybe I can just replace that. Nothing wrong with it except it's faded and looks pink now.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2015 at 10:22am
Rub rails are EXPENSIVE 87 and newer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2015 at 9:32am
Cant help with #1 but that almost sounds like "too good to be true" pricing... Make sure it's the same stuff!
2. Alloy Marine. Be prepared to take detailed measurements, their bookkeeping is horrendous.
3. Depends what color you need... Might be available on eBay if it's a commo size/color, else check with Zach.
4. That's going to be very tough to find, but I don't recall having enough information to be sure that's what you want. A delux #3 (83.5-89) may be too wide for your garage opening (~96"). We know an earlier non-delux #3 (92") will fit, but haven't confirmed the inside fender dimension to know if your boat will squeeze into one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2015 at 12:49am
I'm starting to prepare for the boating season and the time has come to get some parts / components in order.
Questions;
1. Is there a cheaper place to buy a rub rail (other than go2marine)? Looks like it would be about $300 to do the 176 there.
2. Who sources the original "removable" swim platform brackets?
3. I need to replace the vinyl (I think its vinyl) trim tape on the stipe of my boat. It's 1/4" and I'd need 45ft of it.
4. I need a late 80's #3 trailer. Anyone have one?
Chris
