  New Posts New Posts RSS Feed - Wiring harness for 1988 2001
mpotts12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mpotts12 Quote  Post ReplyReply Direct Link To This Post Topic: Wiring harness for 1988 2001
    Posted: February-13-2015 at 6:33pm
Definitely interested.... At work right now but I'll get back to you later. Thanks
lakedog55 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote lakedog55 Quote  Post ReplyReply Direct Link To This Post Posted: February-13-2015 at 6:20pm
I have one,
but they are interesting to make sense out of. all daisy chained together, This one was new probably ten years ago,
Let me know if interested
Mike
Lakedog55
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2015 at 7:20pm
Originally posted by mpotts12 mpotts12 wrote:
Thanks guys! I'll let you know how it turns out
And don't forget:
Alfred,
How about some pictures as well as more info on the boat? A diary entry would be great too.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2015 at 5:52pm
Originally posted by phatsat67 phatsat67 wrote:
The quality of the wiring was ok but not usually good enough to stand up to 30 years of corrosion,
Correct! They didn't even use tinned wire!
Alfred,
I didn't mention the tinned wire. It is recommended as well.
Pete, we just did a complete dash rewire on a Footer. Much better results.
Mine operates pretty well but next winter when I can afford that new dash panel it will be all new and probably quite revised when I get in there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mpotts12 Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2015 at 4:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2015 at 12:12pm
Alfred,
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2015 at 10:26am
Pete will point you in the right direction. The quality of the wiring was ok but not usually good enough to stand up to 30 years of corrosion, vibration, and unqualified mechanics changing things.
It is pretty simple just will take you some time. Doing a full rewire is probably your best option for success in the long run.
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2015 at 9:37am
Alfred,
Welcome to CCfan. How about some pictures as well as more info on the boat? A diary entry would be great too.
You say everything is fine except under the dash. Consider cleaning it up. Many here have and gone with terminal strips to eliminate daisy chaining. Also using adhesive lined heat shrink crimp on connectors is always best. Another upgrade is running heavier gauge wire up the dash. This eliminated the voltage drop many encounter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2015 at 9:21am
Most of that was wired by CC. The only thing that is available is the pig tail end that comes out of the 8 pin connectors and I believe only one of those is still available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mpotts12 Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2015 at 10:50pm
I need the wiring harness for a 1988 2001 ski Nautique. I just need the one that connects everything in the dashboard and control panel..... Gauges, switches ect... Everything up to that point is fine, but from the pigtail that connects everything in the dashboard and control panel has been butchered. Any help would be appreciated.
