  New Posts New Posts RSS Feed - strut leaks
strut leaks
camron18 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Topic: strut leaks
    Posted: April-03-2015 at 4:41pm
Well hopefully that's right. Cuz that's what I did. Covered the strut completely, filled in the countersinks, and put some down the bolt holes from inside. I tightened it urp slowly and the 5200 oozed out the sides. That stuff is sticky!
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-03-2015 at 3:02pm
So im going to use the 5200 to rebed the strut now. What should I do? Put it on the strut all around? A bead of it around the outside? Some on the hull? Put some in the bolt holes from inside the boat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2015 at 9:02pm
Now that you mention it, I guess I didn't need to remove the shaft.. But it was nice to have it out so I could bring it to work today and check if it was bent with an indicator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2015 at 8:43pm
For your convenience here is the original post -
[QUOTE=camron18] well i noticed a lot of play in the cutless bearings, so i removed the shaft and strut and got the old ones ones out. QUOTE]
Well Gary, Cameron wouldn't have been able to remove the shaft completely without removing the coupling which is confusing. The only other option would be to remove the shaft forward but then the engine needs to be pulled. Maybe Cameron can solve the mystery?
The reason I asked about the shaft, is you know it doesn't need to be removed for removing the strut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2015 at 8:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2015 at 7:35pm
As mentioned, no heat but you will need the special removal nut.
Why are you removing the shaft from the coupling????
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2015 at 5:30pm
awesome! Thanks!
Everyone is so helpful!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2015 at 5:25pm
No heat needed for a double taper.
ARE double taper shaft instructions
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2015 at 5:22pm
Okay i got new cutlass bearings in and im ready to dive into the alignment. But i have seen on other posts that i have to heat up the coupling to get it on the shaft. My shaft an coupling are tapered, like the prop end. Should i still heat it up to get it on, or should i just tighten the nut to seat it on the taper like the prop?
Thanks alot
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2015 at 2:27pm
If he has a lot of cutlass bearing wear it is possible the shaft has a bend in it, or maybe just lots of hours on this boat?
I replaced the factory cutlass bearing with the plastic/Delryn type. It has very little drag, fit perfectly and they claim it will last much longer. I have no idea about the lifespan, at 25 hours use it is still very good, I am curious if any here have high hours on this type cutlass bearing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2015 at 8:37pm
Cameron,
You'll most likely be fine with the missing gel as long as the area isn't too big so the strut base still has plenty of support.
How about those pictures?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2015 at 7:57pm
When I took mine apart last year for the same job I listened to the great advice of the experienced guys on this forum. The job turned out perfect and the prop now rotates with one finger sitting dry on the trailer. It used to take a strong hand to turn. Take your time, do it right and you will be very happy with the results.
As far as the chipped paint, you may have chipped the gel coat, most fiberglass boats don't have paint. I think the 5200 would seal right over a chip. It dries very hard and permanent. I used it for the great seal and holding power and I pray I never have to remove it. Do your test fitting. Make sure you read everything about proper shaft alignment and it will come out great.
While at it is good to refresh on proper seating of the prop to the prop shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2015 at 7:44pm
The wear looks even for the most part, but i think that they are long over due for replacing.
another concern is when i took the strut apart from the hull the old epoxy took some paint with it. is this going to be a problem when i rebed the strut? or can i just epoxy right over that spot?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2015 at 7:31pm
Is the wear even? If not, then I'd say you do have an alignment problem. Remember, alignment starts at the strut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2015 at 7:16pm
Check out part # 2204 here ,it seems they use a 2 piece now days. Part #12109 type has been used by a few here with positive results
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2015 at 6:02pm
well i noticed a lot of play in the cutless bearings, so i removed the shaft and strut and got the old ones ones out. I am having a hard time finding new ones.
the old bearings are 1in x 1-1/4in by 2 in long. does anyone know where i can find some this size?
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2015 at 10:19pm
thanks alot! ill give it a try and tell you how it goes!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2015 at 8:02pm
hopefully it will still be aligned when im done? or will it need to be redone?
thanks
Cameron,
You've got the idea but, if it's not aligned when you have it all bolted up, then yes it would need to be partially done again. The nice thing about both 5200 and 4200 is the long cure time. That gives you a chance to loosen and try again. Dry fit and see what happens.
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2015 at 5:49pm
okay so im going to pull the strut off. clean it and the hull where it beds like crazy. put the strut back on dry, check the alignment. if it looks good put 5200 on the strut and in the bolt holes, tighten it on and check the alignment again. does that sound like im on the right track? if it is already good and aligned hopefully it will still be aligned when im done? or will it need to be redone?
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2015 at 10:10pm
Cameron,
You may find that the holes in the hull have been slightly elongated. This is common even at the factory to make minor port to starboard adjustments. As Chris mentioned, tightening the bolts may shift the strut. The other adjustment for up and down would be shims between the strut and hull. It too is a common method even from the factory. For bedding compound, I have a hunch that Hydrodyne used silicone. DO NOT use the damn stuff!!!
After re bedding the strut, make sure you do an engine alignment.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2015 at 9:20pm
Tightening the bolts will shift the strut alignment a little, so my advice is to 'dry fit' it (no goo), torquing the bolts all the way.
Check your alignment one last time & then take it apart & apply the goo.
I hate it when you have to make a modification when it is all dripping with that stuff!
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2015 at 9:09pm
it is a 1994 hydrodyne grand sport with a pcm 351
if my strut and drive shaft and everything are good and aligned now, will it be difficult to get the strut back aligned once i pull it off and put it back on? or would tightening up the bolts evenly get it aliened again?
thanks for the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2015 at 8:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2015 at 8:39pm
Cameron,
Welcome to CCfan.
How about telling us more about the boat and pictures are always welcome. If it's a CC, submit an entry to the diary section.
The sealer goes outside between the strut and hull as well as in the bolt holes. 5200 is best for adhesion and 4200 is good but not as strong. The nice thing about the 4200 is it's easier to remove. When you loosen the strut, do keep in mind alignment. I'll link the alignment thread for you to watch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2015 at 8:35pm
The question is whether 5200 is too strong of an adhesive for strut use. Some people prefer sealants with lesser adhesive properties (like 4200 or life boat caulk). I've used 5200.
Either way, you'll want to bed the strut- don't seal the backing plate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: March-05-2015 at 8:15pm
i have noticed water coming in my boat from around the strut back plate. i have seen people say to use m3 5200 and people say to never use it. What do you suggest? also would i put the sealer inside on the back plate or outside the boat between the strut and the hull?
anything helps
